Old 10-09-2014, 03:32 PM   #1
torqueno
Is there a clutch delay valve on BRZs? Chirping noises...
I owned an M3 before buying my BRZ, so I'm used to weird moaning/grunting noises from the rear diff and things like that. M3s have this part called a "clutch delay valve." Many M3 owners take it out for faster and smoother shifts. I'm wondering if there is a clutch delay valve that we can remove on the BRZ, because I'm letting the clutch out faster than it is actually "catching" if you know what I mean. It's quite annoying, and I intentionally have to delay letting the clutch out in between shifts for a smoother transition. It's most noticeable shifting into 6th gear.
Also, I'm noticing this weird chirping/quacking noise every time I let off the clutch pedal to engage the next gear. It's most noticeable when I'm in motion on the freeway. There are so many noises this car has compared to my old car that I can't tell if it's good or bad. Please advise!!! Thanks!
In case you're wondering, the car drives fine. I'm just puzzled by the weird noises and clutch timing. Currently has 2,100 miles on it.
torqueno is offline   Reply With Quote
Old 10-09-2014, 03:41 PM   #2
V3rtigo
Drives: 2006 S2000
Not sure what goes on in the brz but here's what subaru does on the sti. http://www.iwsti.com/forums/diy-mods...-method-4.html
They add the delay valve to prevent you from shocking the drive train by sidestepping the clutch or just releasing it quickly. The clutch itself is also sprung too for this same reason. Removing the valve from the slave cylinder is more likely to make your shifts jerky than anything else.
V3rtigo is offline   Reply With Quote
Old 10-09-2014, 03:41 PM   #3
STV3
Señor Member
STV3's Avatar
I don't believe our cars have a clutch delay valve. I know some people remove the spring on our clutch pedal to give it a more solid/less toy like fee. People have reported smoother shifting after removing that spring.
I was always under the impression that the delay was actually in the throttle itself due to the drive by wire set up we have. This is my first car that has a drive by wire throttle and I hate it!.
Oh and that noise is coming from the throwout bearing and is normal. Some peoples are louder then others. My car makes the noise, but it isn't loud enough to bother me.
STV3 is offline   Reply With Quote
Old 10-09-2014, 09:18 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
There isn't a clutch delay valve but the clutch pedal always feels a little vague to me.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
hmong337 (10-10-2014)
Old 10-09-2014, 10:21 PM   #5
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
Originally Posted by torqueno View Post
I owned an M3 before buying my BRZ, so I'm used to weird moaning/grunting noises d to my old car that I can't tell if it's good or bad. Please advise!!! Thanks!
I can't speak for anyone else's BRZ but mine is a symphony of constantly changing and somewhat amusing noises.
Chirps, rattles,buzzing,motor boating, diesel like sounds, cyclic chassis droning etc...they come and they go...eh(shrug)
... now that I have some miles on it, and it has been reliable, I no longer worry about the sounds.
Now about the automatic headlight setting that shuts off the headlights only about 98% of the time..damn that 2%
Ernie L is offline   Reply With Quote
Old 10-10-2014, 01:30 AM   #6
Poodles
Drives: 2015 Series.Blue
It was never 100% confirmed that there isn't a delay valve as nobody has dissected the master and slave yet.
Regardless, the sound is likely something else (clutch fork is dry, etc)
Old 10-10-2014, 12:36 PM   #7
torqueno
Thanks all for your responses.
I'll look into removing that spring. I don't know if the keywords I'm using are incorrect, but I can't seem to find a DIY Write-Up on this.
This is interesting. None of the motorsport shops have bothered to look into this? In my opinion, this subject is a big deal!
Old 10-10-2014, 12:48 PM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
You think our clutch is bad? Try a 2014 tc, my girl just got one. The clutch feels like our gas pedal lmao
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Clutch Delay Valve? ashtray Engine, Exhaust, Transmission 72 11-18-2015 12:10 PM
adjustable valve for clutch for launching? mike the snake Tracking / Autocross / HPDE / Drifting 6 07-22-2014 06:39 PM
Weird noises mamamiaellis Issues | Warranty | Recalls / TSB 4 05-30-2014 04:17 PM
Clutch Delay Valve? Figo Engine, Exhaust, Transmission 14 03-01-2014 11:38 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 12:26 AM
