Old 10-04-2014, 02:52 AM   #1
Fastbrz
Drives: Wrb brz
Differential decisions
Trying to pick between a 1.5 and 2 way differential for road racing/ auto x the car will also be driven on the street. Any help would be appreciated.
@CSG Mike
Fastbrz is offline   Reply With Quote
Old 10-04-2014, 11:52 AM   #2
CSG Mike
CSG Mike's Avatar
1 or 1.5 way; 2 way is typically reserved for drifting.
Old 10-04-2014, 04:28 PM   #3
Fastbrz
Drives: Wrb brz
Would you happen to know what the cusco differential is rated for and or other brands you would recommend for high hp use?
Old 10-04-2014, 09:24 PM   #4
CSG Mike
CSG Mike's Avatar
We share diffs with a MKIV Supra; unless you're making power up in 2JZ range, don't worry about the diff. You have other things that will break first (e.g. axles)
Old 10-04-2014, 11:49 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Is that because of the design? Im just curious as to know why FBM would offer the 8.8 ford rear end for our cars when 2JZ 'range' is like 800-1000whp
Old 10-05-2014, 01:20 AM   #6
CSG Mike
CSG Mike's Avatar
Parts bin... it's on a LOT of Toyotas.
Why they offer it? Because people will buy it.
I wouldn't put 800whp though the stock rear diff though.
Old 10-05-2014, 01:22 AM   #7
Fastbrz
Drives: Wrb brz
@CSG Mike
What version of the cusco lsd do you recommend?
Old 10-05-2014, 01:28 AM   #8
CSG Mike
CSG Mike's Avatar
@CSG Mike
What kind of power level?
Tires?
Suspension?
Driver experience level?
You can't go wrong with a Cusco RS or OS Giken.
Old 10-05-2014, 01:37 AM   #9
Fastbrz
Drives: Wrb brz
Tires?
Suspension?
Tarmac 2 coil overs, apr gt250 wing,
Perrin Steering Rack Lock
GrimmSpeed Master Cylinder Brace
Perrin Front Control Arm Brace
Perrin PSRS - Offset
Perrin Rear Endlinks
Perrin Urethane Front Endlinks
Perrin Transmission Support Mount
Whiteline Positive Traction Kit
Essex Sprint brake kit
Driving experience- 1 track day or otherwise amateur
Tires proxes r888 -3 camber front -2 rear, slight toe in rear
Engine- gtx2867 with meth injection. Not finalized but around 400whp
Old 10-05-2014, 01:44 AM   #10
Fastbrz
Drives: Wrb brz
Other mods include
Wheels k57 CCW front- 18x10 +13 offset. Rear 18x11 -13mm
Rocket bunny kit v2
Sparco EVO seats
Rear seat delete
cipher 5 point harness
Essex harness bar
Exedy twin disk
Mishmoto oil cooler
Aquamist meth injection kit
Perrin header back system
Ft86speedfactory lightweight battery kit
DeatSchwerks fuel pump
SeibonCarbon fiber hood DV style
Aero catch hood pins
AEM guages
Old 10-05-2014, 02:27 AM   #11
CSG Mike
CSG Mike's Avatar
You'll be fine with the type RS. PM us for a quote
Decisions decisions... amilleri Scion FR-S / Toyota 86 GT86 General Forum 26 05-05-2014 03:33 PM
Decisions !!!! DanoFA20 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-18-2012 09:46 PM
Automatic or Manual Transmission? Decisions, decisions... Bfly Engine, Exhaust, Transmission 27 07-08-2012 03:25 PM
decisions... EPIKsung Scion FR-S / Toyota 86 GT86 General Forum 9 06-16-2012 10:22 PM
Decisions, decisions... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 24 05-16-2012 01:18 PM
