Old 08-08-2014, 08:21 AM   #99
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
In this case 1.2 to 1.3 load and RPM 6100-6700 and the ECU is pulling about 2 degrees so remove about half that ie about 1 degree or slightly more from the cells in that area ie load 1.2-1.3 and rpm 6100-6700 area out of the Base_Timing_B table.
so what's going on here now? lol that RPM range is clear and now it's in the 2-3k range...IA seems to be 5-10* there which is low, is this just from chugging the engine in 3rd and below 2k RPM?
http://datazap.me/u/silver-ignition/...=0&data=1-4-12
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-08-2014, 08:39 AM   #100
Silver Ignition
APEXHNTR
this article is exactly what I was looking for. Plain-English explanations of this alien technology lol
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
steve99 (08-08-2014)
Old 08-08-2014, 04:39 PM   #101
steve99
Drives: FT86
When you trying to eliminate knock
the knock sensor is basicly a sensor tuned to recognize the sound frequency/vibration of knock. Sometimes it get's it wrong or some other noise/vibration/resonance "sounds" like knock to the sensor. Their have been cases where a washer/loose nut or vibrating exhaust has set of the knock sensor.
1. make sure its consisent or repeatable at a particular load/rpm point
2. if it only -0.7 or less it can be very difficult to eliminate completely especially in the 1500-3500 rpm range with these motors especially on throttle tip in.
3. If you jump on the gass at low rpm in high gear it probably going to get a bit of knock 0.7 or so.
4. log your STOCK tune and you will be surprised how much these motor knock on factory tune even with 93 fuel. I've seen stock tune pull -4 degrees and have IAM running at 0.7-0.6 running on 98RON fuel in city traffic low rpm high load.
Old 08-08-2014, 04:45 PM   #102
steve99
Drives: FT86
just be aware it aimed at WRX ie boosted the IAM is different 0-16 as opposed to 0-1 and they talk much richer AFR than BRZ/86 high rpm/load due boost.
Silver Ignition (08-08-2014)
Old 08-08-2014, 05:17 PM   #103
Silver Ignition
APEXHNTR
still have it up high...
http://datazap.me/u/silver-ignition/88?log=0&data=1-12
#1867 of 2500
Old 08-08-2014, 05:43 PM   #104
steve99
Drives: FT86
Assume You have BPB and have made the BPB changes to timing maps,as the knock is occurring where the BPB map has been advanced by 3 degrees.
You might have to talk to shiv its best to email him (PM don't work), it looks like the BPB changes to recover the lost power at high RPM are not working for you, it might just be your fuel. Best to run it past shiv I think, you might just have to reverse the BPB changes.
Old 08-08-2014, 06:01 PM   #105
Silver Ignition
APEXHNTR
@Shiv@Openflash? What do you think?
I guess I could upload a non-BPB map and see what happens, right?
#1867 of 2500
Old 08-08-2014, 07:01 PM   #106
steve99
Drives: FT86
I can't see it being a problem other than the power past 6000 may be down a bit but if its pulling timing anyway their won't be much difference.
the whole idea of the BPB was to bring the powerband lower in the rpm range anyway.
Old 08-08-2014, 11:01 PM   #107
Silver Ignition
APEXHNTR
Okay here's the Stage 1 93 tune on 93 fuel
I'll try Stage 1 91 tune on 93 fuel tomorrow
#1867 of 2500
Old 08-08-2014, 11:29 PM   #108
steve99
Drives: FT86
Shiv kind of suggested the additional timing advance may be an issue for some people
From Shiv's Original Post in this thread
"Step 7: Take some datalogs of 3rd gear WOT runs (2000-7500rpm) and confirm that there is little to no knock correction. Especially above 6000rpm where you made the adjustments."
Shiv has to cater for varying conditions and fuels and its much easier to see where to pull timing than where you can add it without a dyno and extensive knowledge and we need to keep in mind these are OTS maps.
Silver Ignition (08-09-2014)
Old 08-09-2014, 08:25 AM   #109
Silver Ignition
APEXHNTR
Yeahh I hear you. Would it be a good idea to run these tunes for a few days and a few hard runs to see if the timing comes back up? Am I tainting the diagnostic process by changing tunes every day?
#1867 of 2500
Old 08-09-2014, 04:40 PM   #110
steve99
Drives: FT86
My experience is ECU learning is pretty quick, 20 minutes normal driving is plenty even less if fuel trims (MAF Scaling) is good, the Knock correction tables fill very quickly and if your running the right fuel/tune they shouldn't be needed much anyway.
If you were running lean due fuel trims may impact on knock, but you look plenty rich up top end and fuel trims look fine around 3%
The main impediment to learning fuel trims is driving the car hard and WOT straight up, ECU only learns fuel trims in "closed" loop mode this is when your idling, smooth/steady throttle movements and cruising. If you fuel trims are less than about 4% it not going to get any better.
If you do 2 or 3 "vishnu reset" runs ie partial light (20% or so) steady throttle runs from 2000-5000rpm or so in 3rd it will set your fuel trims and reset you IAM (assuming is not knocking) if its less than 1. The gear is not rearly important its the partial steady throttle the longer the run the better. A slight uphill grade can be useful (or you can left foot brake). This works anytime to reset IAM back to 1 (assuming its not knocking at light load) it usefull when your chasing knock in an area and want IAM back to 1.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
Shiv@Openflash (08-09-2014), Silver Ignition (08-09-2014), Walla Walla (08-09-2014)
Old 08-10-2014, 04:45 PM   #111
Silver Ignition
APEXHNTR
odd…so I flashed back to the Stage 1 91 tune with BPB changes and no other modifications and I now have FLKC, IAM and Knock Correction all flatlined so far…gonna keep data logging. As outlined in that one article I changed my retard settings to 1.01 and my advance settings to .20 to easier keep track of how often it's retarding and advancing timing
#1867 of 2500
Old 08-11-2014, 06:44 AM   #112
silverbullet
Drives: 2013 BRZ LTD Silver
I've been having the same issue with knock between 5800-6800 with the 93 tune with BPB modifications. Been trying to tune it out for a week. I've pulled about 3 degrees of timing in that area and I'm already running plenty rich and still getting the knock. I'm going to try the 91 tune with 93 octane later today, hopefully it helps.
silverbullet is offline   Reply With Quote
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
