Old 06-09-2014, 09:18 PM   #1
Stormalong
Drives: Firestorm FR-S AT
Effect of cat delete
Hey guys, I'm new to this stuff, so forgive the noob question.
What would be the sound and performance effects of a cat delete on the stock exhaust? (I already know it will make you fail the emissions test).
I'm curious if anyone actually knows the answer to this, because it seems like something people never do (ie if they do a cat delete they also change other things at the same time, so you can't isolate the effects of just the cat delete).
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
Old 06-09-2014, 09:26 PM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Are you keeping the stock header? If you are, you will just gain some volume in your exhaust note. If you will be swapping a catless header, your exhaust note will be raspy.
Tye300 is offline   Reply With Quote
Old 06-10-2014, 03:19 AM   #3
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Not sure about performance gains/losses, but here are a couple sound clips comparing 100% stock vs resonated cat delete.
[ame]http://youtu.be/ytvCLr-XM2U[/ame]
[ame]http://youtu.be/SF8uvoWga7E[/ame]
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
The Following 3 Users Say Thank You to edeekeos For This Useful Post:
Createddeleted (11-24-2014), mattbenich (06-14-2014), Stormalong (06-10-2014)
Old 06-10-2014, 03:22 AM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Performance wise, yes there will be an increase over stock. That said, the difference between a cat delete pipe and a HFC pipe is like 1 hp, but with the addition of being able to pass emissions, and less rasp.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 06-10-2014, 03:26 AM   #5
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Funny, as I was about to ask the same thing. I'm getting a Milltek exhaust system installed on Friday, and am trying to decide on the primary catback (secondary cat delete) or the secondary catback (no cat delete), and if I'd notice any difference between the two in sound or performance (with no tuning). Any recommendations?
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 06-10-2014, 04:06 AM   #6
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Yes it'll be noticeably louder/ faster. Factory cats are restrictive. High flow cats would be good alternative if you wanna keep emissions.
h4nh is offline   Reply With Quote
Old 06-10-2014, 05:13 AM   #7
s2d4
s2d4's Avatar
Until someone has passed emissions, it's all speculations at this point.
There is no rasp if your remove header only, otherwise if you have the right CBE, no rasp either. Not much performance wise after replacing headers unless FI.
People make the mistake of doing back to front, should definitely attempt from header back in terms of sounds and performance.
Old 06-10-2014, 09:06 AM   #8
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
Is it really possible to pass emissions testing with a HFC? I've yet to see a post on this board where someone says they have. Is there anyone out there who can speak from direct experience? My gut feeling is that any changes to the header or cat will likely lead to failing the emissions test, but what do I know, I only stayed in a Holiday Inn Express a couple of weeks ago.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 06-10-2014, 09:28 AM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
There's no blanket statement for passing emission testing. Each state is different. In the states that my car is registered (VA, AL, GA) I know what the requirements are to keep my vehicles street legal, all the way down to the tint requirement.
With that being said, a cat is a cat, in those states, whether it's built into the header or is a HFC. In California that previous statement isn't true. In the states I listed only 1 cat is required, not 2 so a free flowing header can be added and a front pipe that incorporates an HFC.
In regards to emission/smog testing you'd be better off knowing the laws for your state and county. For example, only in GA only vehicles registered in the counties adjacent to and within the city limits of Atlanta have emission testing, all the others do not.
Some states require a visual test, some only require an OBDII readiness check...it's best to know your own laws than rely on a blanket statement on a forum.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 06-10-2014, 10:46 AM   #10
s2d4
s2d4's Avatar
There is no cat in the midpipe.
Old 08-16-2018, 12:28 AM   #11
BOND007_LTK
Drives: 2013 brz
But one in the front pipe apparently. Plus 1 in the header.
BOND007_LTK is offline   Reply With Quote
Old 08-16-2018, 12:41 AM   #12
FirstWinter
Drives: Car
@BOND007_LTK
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
jflogerzi (08-16-2018)
Old 08-16-2018, 01:05 AM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by FirstWinter View Post
Yea holy shit how the hell you manage to necro a thread from 4 years ago with a response like that
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Does Turbo effect gas milage?? beesmiff07 Forced Induction 86 10-30-2014 10:25 PM
Effect of using of spacers for rear-only mit_peid Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-05-2013 01:06 AM
Carbon Effect Wing Mirrors faz1 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-25-2012 09:12 PM
Effect of shifter knob weight BMWDavid Engine, Exhaust, Transmission 3 08-03-2012 11:32 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 11:49 AM
