Old 10-28-2013, 05:23 PM   #29
liajet24
Drives: Argento FRS
I ripped the front badge off a paseo and literally just double sided taped it on. and you wouldn't be able to tell unless you go right up to it and look that its stuck on
liajet24 is offline   Reply With Quote
Old 02-11-2014, 04:06 PM   #30
Randyliciious
Randyliciious's Avatar
Drives: 2013 Whiteout FR-S
Originally Posted by Nothing View Post
Got mine done too!
Attachment 55237
Sent from my iPhone using Tapatalk - now Free
What did u use behind your emblem??
Randyliciious is offline   Reply With Quote
Old 02-12-2014, 03:40 AM   #31
Nothing
Drives: FRS
A black plastic mouse pad. It separates from the foam/rubber under it and you can attach it to the back of the Toyota logo and then to the steering wheel.
Nothing is offline   Reply With Quote
The Following User Says Thank You to Nothing For This Useful Post:
Randyliciious (02-21-2014)
Old 04-13-2014, 05:03 PM   #32
jkr
jkr's Avatar
Drives: '13 frs
just out of curiosity if the airbag were to deploy with this diy badge, would you have a toyota emblem stamped on your face or is the way the airbag is designed to break apart more clever than that ?
jkr is offline   Reply With Quote
Old 04-14-2014, 02:57 PM   #33
ScorpionOzzy
Drives: Scion FR-S
I said the same thing in another thread and most bashed me and thought I was crazy. But to answer you, yes you probably would have a toyota stamped on your face.
ScorpionOzzy is offline   Reply With Quote
The Following User Says Thank You to ScorpionOzzy For This Useful Post:
jkr (04-14-2014)
Old 04-15-2014, 01:11 AM   #34
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Nice!
Jolaessss is offline   Reply With Quote
Old 04-25-2014, 11:16 PM   #35
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Oh well saves cost on the tattoo ROFL
zohare is offline   Reply With Quote
Old 04-25-2014, 11:28 PM   #36
FRSure
Drives: Toyota
I don't get this.. But wouldn't scion be stamped on our face without the emblem swap.. This isn't removing part of the airbag, just the emblem.
FRSure is offline   Reply With Quote
Old 04-26-2014, 12:42 PM   #37
ScorpionOzzy
Drives: Scion FR-S
and what happens when the airbag deploys? You're not removing part of the airbag. You're removing something that was part of the outside of the airbag, with something that is now just questionably stuck on, in FRONT of an EXPLODING airbag. There is a certain tear line along the leather on the bag that tears apart when the airbag deploys. It tears around the scion logo so when the airbag deploys, the badge stays stuck to one of the flaps.
Like This:
The Scion badge is adhered on there with strong adhesive and what look to be plastic pins, to keep it attached when the airbag deploys. and let me also say that it has been TESTED by the manufacturer. If your glued toyota badge doesn't stick properly to the airbag, or the glue isn't stong enough. When the airbag deploys WITH STRONG FORCE, the badge will become a projectile.
FRSure (04-26-2014)
Old 05-26-2014, 07:10 PM   #38
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
did mine a couple days ago... im very satisfied with how it came out.
i used adhesive-backed black crafts foam lying around for the backing.
zAnSh1n is offline   Reply With Quote
The Following User Says Thank You to zAnSh1n For This Useful Post:
Dadhawk (05-26-2014)
Old 06-01-2014, 03:12 PM   #39
SupremeOrigin
Drives: 14' FRS, 90' Miata
Just ordered mine, can't wait to replace these scion badges...
SupremeOrigin is offline   Reply With Quote
Old 06-05-2014, 07:39 AM   #40
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
You guys do realize you're putting an insecure object, on top of a bomb, that can go off at any time, directly in front of your face??
Definitely looks awesome though - it's really funny seeing everyone jump on board using different backgrounds.
rmjjensen is offline   Reply With Quote
Old 06-05-2014, 08:59 AM   #41
Yrr
Yrr's Avatar
Drives: Toyota GT86
Like This:
Does anybody knows where the airbags break/trear-lines are located on the GT86 steeringwheel?
I was thinking to order this emblem but I don't want to engrave a 86 logo into my face if something bad is gonna happen.
Yrr is offline   Reply With Quote
Old 06-05-2014, 12:56 PM   #42
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i disconnected my airbag along with "airbag light delete"...
seat belt + curtain/side air bags are enough for me
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
Steering wheel swap questions firl21 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-02-2014 08:27 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Would it be easy to swap the front of my steering wheel? bdanisi Scion FR-S / Toyota 86 GT86 General Forum 9 05-11-2013 03:34 PM
Swap your Scion key emblem for a Toyota Synack Scion FR-S / Toyota 86 GT86 General Forum 6 08-03-2012 05:58 PM
