Old 05-20-2014, 12:16 AM   #1
scionfrs2014
Drives: Scion FRS
How does AC impact power?
AC consumes power. I try to use minimum AC as I need. My Scion FRS has a manual-controlled AC wheel. Does it consume more power if I turn the AC wheel to the maximum versus turn to the middle? Thanks.
Update - to clarify my question, does FRS/BRZ's AC just have binary mode, on and off? Or can it work progressively as the control-wheel? turn?
scionfrs2014 is offline   Reply With Quote
The Following User Says Thank You to scionfrs2014 For This Useful Post:
SirBrass (05-20-2014)
Old 05-20-2014, 12:26 AM   #2
Snowblind
With the AC off you will get beat in a race by a Camry.
With the AC on you will get beat in a race by a Corolla.
The Following 16 Users Say Thank You to Snowblind For This Useful Post:
Alltezza (03-18-2018), CatDaddysBBQ (05-21-2014), continuecrushing (05-21-2014), Crashdummy (03-18-2018), driftking96 (05-19-2016), ERA (03-19-2018), gramicci101 (05-21-2014), guybo (03-19-2018), JD001 (05-13-2019), Mr.ac (03-19-2018), Pseud0logik (05-21-2014), SCQTT (03-19-2018), Starkiller (05-20-2014), tCsonfrs (03-22-2018), tennisfreak (05-21-2014), Thrustin (05-21-2014)
Old 05-20-2014, 12:38 AM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Horse shit on both accounts. Learn to downshift.
I've not really noticed a significant power drop either way. But as to the OP's question, yes it will use more power as you're asking the AC compressor to work harder by removing more heat.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
JohnJuan (05-20-2014)
Old 05-20-2014, 12:41 AM   #4
Well, yes, the more the compressor runs, the more power it consumes.
Having said that ..... my personal experience has been that I'm much more "comfortable" if mrs humfrz is comfortable. Now, if I turn the little wheel so that she is most comfortable ..... it may cost another 1/2 cent per mile ..... on the other hand ...... the "cost" of living through one of mrs humfrz's hot flashes is .......
The Following 25 Users Say Thank You to humfrz For This Useful Post:
13un (05-21-2014), 8RZ (03-19-2018), Adam_L (05-12-2019), Braces (05-20-2014), Chattanooga FR-S (05-20-2014), Churnobyl (05-21-2014), e_lunatic (05-13-2019), Fly Guy (05-20-2014), Fortis (05-21-2014), FreshFRS (05-21-2014), g e (03-18-2018), JD001 (05-13-2019), JoeHK (05-20-2014), JustBoostin (05-20-2014), Jyn (05-20-2014), Mad1723 (05-20-2014), Mister (05-20-2014), onefitz (05-21-2014), pcporo (05-20-2014), Purdue FR-S (05-20-2014), Quentin (05-20-2014), Ramster (05-21-2014), Rayme (05-21-2014), SirBrass (05-20-2014), STV3 (05-21-2014)
Old 05-20-2014, 01:01 AM   #5
Bailey
Drives: 2013 Raven FR-S
The blower fan speed doesn't have an effect on power (aside from the miniscule electrical draw), just the AC On/Off. Adding any accessory that's belt driven will theoretically cause a loss in power. Superchargers overcome it with boost, but AC compressors just draw power while in use.
I don't know if the varying degrees of AC matters as much as simply On/Off, in terms of power loss.
Bailey is offline   Reply With Quote
The Following User Says Thank You to Bailey For This Useful Post:
strat61caster (05-20-2014)
Old 05-20-2014, 01:09 AM   #6
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Camry V6 maybe (but it will be close).
Corolla - no way in hell. My previous car was a 2009 Corolla XRS - the FR-S is definitely faster (regardless of AC).
Demandred7 is offline   Reply With Quote
The Following 2 Users Say Thank You to Demandred7 For This Useful Post:
Adam_L (05-12-2019), SirBrass (05-20-2014)
Old 05-20-2014, 01:55 AM   #7
DC2R
Drives: 2014 Scion FR-S
The car stitches off the compressor when you get on the gas. You shouldn't feel much loss in power when you need it. That being said down here in humid Miami that kind of sucks since it never cools car down unless I drive like a granny.
I have a question of my own. It's this car just like an old Honda ever the temperature dial is just a direct connection to the heater block valve? For example the a.c. is always on max and moving the dial away from max just add coolant into the mix?
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-20-2014, 01:57 AM   #8
Yrr
Yrr's Avatar
Drives: Toyota GT86
LOL quite the same "issue" over here.
Yrr is offline   Reply With Quote
Old 05-20-2014, 09:41 AM   #9
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
1) A/C at full load conditions requires about 3-5 HP.
2) A/C does not run continously, but cycles off and on.
3) A/C drops out at WOT.
billwot is offline   Reply With Quote
The Following 4 Users Say Thank You to billwot For This Useful Post:
Busybee (03-20-2018), DC2R (05-21-2014), feedbag (05-22-2014), JohnJuan (05-20-2014)
Old 05-20-2014, 12:12 PM   #10
pasternak
Drives: Asphalt FR-S
I've noticed minimal power loss from the AC. Adding a passenger kills the power way more.
pasternak is offline   Reply With Quote
Old 05-20-2014, 12:55 PM   #11
irucremmi
Drives:
Reroute air vents into air intake when ac on for more powah... : P
irucremmi is offline   Reply With Quote
The Following 3 Users Say Thank You to irucremmi For This Useful Post:
e_lunatic (05-13-2019), gramicci101 (05-21-2014), Surok (03-18-2018)
Old 05-20-2014, 01:34 PM   #12
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Yes... AC makes cold air and is mixed with hot air to obtain the required temp. When AC is on it doesn't matter what temp you set, the required power is that of turning the pump (approx 8HP I've often read...) But as stated, normally the ECU cuts the AC when full throttle, so you shouldn't really feel power drop but rather temperatur increase in the cabin!
Harvey is offline   Reply With Quote
The Following 2 Users Say Thank You to Harvey For This Useful Post:
DC2R (05-21-2014), scionfrs2014 (05-20-2014)
Old 05-21-2014, 05:50 AM   #13
Maritime Storm
Maritime Storm's Avatar
Drives: 2013 Scion FR-S 6spd, Whiteout
HUMFRZ; Sums it up nicely. If Momma ain't happy, ain't nobody happy. Worse than that, if Momma ain't happy, I get stuck in the passenger seat real quick.
Maritime Storm is offline   Reply With Quote
The Following User Says Thank You to Maritime Storm For This Useful Post:
humfrz (05-21-2014)
Old 05-21-2014, 08:57 AM   #14
bluesman
Drives: 2015 FR-S
Ahhh - the blessings of womanhood......
But I was under the mistaken impression that this is a temporary phenomenon that will resolve over time. I can testify under oath that this is simply not so. Some nights, I wake up with no covers and find the entire blanket and quilt wrapped around my wife. Others, I wake up to an open window in the middle of winter. Yet the hormone levels dropped along with Ross Perot's shot at the White House.
Words to live by: "Trusting a menopausal woman to control her emotions is like trusting a tornado to mow your lawn." (And I'm just not being a MCP - it's no more pleasant for them than it is for us.)
bluesman is offline   Reply With Quote
The Following User Says Thank You to bluesman For This Useful Post:
humfrz (05-21-2014)
Way too loud. Best fix for minimal impact? transition Engine, Exhaust, Transmission 55 07-24-2014 11:02 AM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
[SYD] Milwaukee M18 1/2" High-Torque Impact Wrench 2663-22 eckoflyte Australia Classifieds 2 08-27-2013 05:19 AM
Affordable Battery Impact Gun/Drill that can handle lug nuts swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 07-29-2013 11:46 PM
HOW PHOTOGRAPHY CAN IMPACT DETAILING RESULTS Greg Gellas Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 03-23-2013 02:18 AM
