Old 04-20-2014, 02:32 PM   #1
CIAGDDS
Drives: BRZ-L
DIY: Disable Compass Rearview Mirror (Auto-dimming Mirror)
This is for anyone that hates the compass feature. Every time I start the car I have to turn off the compass because it annoys me.
Step 1: Remove the mirror with a T20 Torx bit. Slide the base up towards the ceiling. Disconnect the connector behind the mirror.
This is what you're working with. You will need a plastic pry bar or something similar to open the casing without damaging it. I think I got mine at harbor freight.
Step 2: Pinch the top and bottom of the casing near the side with your fingers and slide the plastic pry bar into the side of the casing. You need to get it in about ¼ inch and then proceed to slide the pry bar around working your way around the top of the mirror across to the other side and down to the bottom. Work on the bottom portion last as it is more secure there. ***You DO NOT need to twist or pry the plastic, just slide the pry bar around the edge about ¼ inch deep***
Now you can lift the housing off:
This shows all the brackets around the edge:
Step 3: Flip the mirror over and the internal parts should fall out of the housing. On the back of the circuit board you will see a positive and negative cable attached to posts. I disconnected these by sliding them up with the plastic pry bar.
Step 4: Separate all parts.
Here is the Compass Display:
Step 5: Cover the Compass Display with electrical tape so you don't have to mess with the any of the circuits and it can easily be reversed. ***If you want to protect the display from the sticky electrical tape, cut a piece of paper the size of the display and put it between the tape and the display.
Step 6: Reverse order and put it back together. Enjoy not have a Compass in your peripheral vision and reflecting off the dome light.
CIAGDDS is offline   Reply With Quote
The Following 3 Users Say Thank You to CIAGDDS For This Useful Post:
codesplice (04-21-2014), Ohio Enthusiast (05-15-2020), unsurety (04-21-2014)
Old 04-21-2014, 05:28 AM   #2
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Thanks for making it so simple to disable, Subaru!
unsurety is offline   Reply With Quote
Old 04-21-2014, 06:51 AM   #3
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I have a standard mirror, just wondering what makes it so annoying?
Gords_zenith is offline   Reply With Quote
Old 04-21-2014, 10:38 AM   #4
CIAGDDS
Drives: BRZ-L
It's annoying to me because I can't stand the red light in my peripheral vision and it reflects off the map lights above it making it double up. It's really just personal preference. I also don't need a stupid little compass to tell me which direction I'm heading.
The Following User Says Thank You to CIAGDDS For This Useful Post:
Gords_zenith (04-21-2014)
Old 04-22-2014, 04:14 PM   #5
SlowGT
Drives: 2013 FRS
Never bothered me, but kudos.!
SlowGT is offline   Reply With Quote
Old 04-22-2014, 04:16 PM   #6
CIAGDDS
Drives: BRZ-L
If anything, now people know how to open the mirror up. That's why I put the tutorial together anyway. I couldn't find anything on opening it up.
codesplice (04-22-2014)
Old 04-22-2014, 04:21 PM   #7
TM
TM's Avatar
Drives: DGM BRZ 6MT
Thanks for the images. Might be helpful if and when I decide to look into putting my radar display into the mirror.
The only comment I have is to be cautious of handling circuit boards on or near a carpet/rug. My friend fried his motherboard from the static buildup from his rug.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
Old 04-22-2014, 05:28 PM   #8
OrbitalEllipses
Drives: Attitude
You must have an excellent sense of direction! Are you part carrier pigeon?
chas3wba0 (04-22-2014)
Old 04-22-2014, 05:30 PM   #9
CIAGDDS
Drives: BRZ-L
Well, I'm not out 4x4ing my BRZ. When you live somewhere for 30+ years you kinda know where you're going. Thanks for your concern though.
Old 04-22-2014, 06:02 PM   #10
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
why would this annoy anyone?
Goya is offline   Reply With Quote
Old 04-22-2014, 06:48 PM   #11
CIAGDDS
Drives: BRZ-L
Are you just trying to get your post count up?
Old 04-22-2014, 06:54 PM   #12
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
That's a lot of trouble for a red light. Must be really annoying.
AVodka14 is offline   Reply With Quote
Old 04-22-2014, 06:58 PM   #13
CIAGDDS
Drives: BRZ-L
Yup, highly annoying and nope, not much trouble at all. Probably take about five minutes out of your day.
Old 04-22-2014, 09:39 PM   #14
AVodka14
AVodka14's Avatar
Gotcha. I am going to buy an autodimming mirror from SubaruPartsOnline. Was going to get the one with compass built in only because it has the Homelink. Good to know it can be easily disabled.
compass, disable, rear view, rearview
Auto dimming / compass mirror Apecks Interior Parts (Incl. Lighting) 3 02-10-2014 02:28 PM
Subaru brz/scion fr-s auto dimming mirror w/ homelink & compass Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2013 12:36 AM
WTT: my dimming/compass mirror for your HomeLink mirror Apecks Interior Parts (Incl. Lighting) 0 04-07-2013 12:24 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 12:19 PM
