Old 04-08-2014, 11:21 AM   #1
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
How to jack up one side of your car without damage
First off, the preferred way to jack your car is at the front & rear jack points as covered previously by GrimmSpeed (thanks guys), linked here
http://www.ft86club.com/forums/showthread.php?t=10111
However, this doesn't work very well for tire rotation (unless you put one end on jack stands) and there's a faster way.
Pictures tell the story best. That's a $2 hockey puck, about 1/3 cut away with a sawsall and metal cutting blade (put the puck in a vise, please).
I locate the flat (i.e. sawn off) edge of the puck on the inside of the pinch weld at the factory designated front jacking point and crank away. No funny noises, no distress, no bent pinch welds, no chipped paint. Happy jacking...
Ralph Spoilsport is offline   Reply With Quote
The Following 2 Users Say Thank You to Ralph Spoilsport For This Useful Post:
tobin (04-08-2014), ZionsWrath (04-08-2014)
Old 04-08-2014, 11:31 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
fap fap fap
Old 04-08-2014, 12:01 PM   #3
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
This is how I always jack this car up. Seems fine as long as the jack has the right cup for the pinch weld.
I'll be installing coil overs one side at a time this way. I also put a second jack under the rear pinch weld for additional support.
GTHachiRoku is offline   Reply With Quote
The Following User Says Thank You to GTHachiRoku For This Useful Post:
Old 04-08-2014, 12:22 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I got this:
http://www.purems.com/Products/PROTE...-Lift-Jack-Pad
Easier if you do one end of the car at a time... the above method is okay for wheel changes, but for suspension swaps you would end up fighting the sway bars as it's loaded on one side.
-alex
Old 04-08-2014, 12:31 PM   #5
sshole
Use some jack stands, please. The last thing you want is to wiggle your car while it's on jacks and have the jacks move/topple over along with the car. Then you'll have a whole new set of problems....
sshole is offline   Reply With Quote
The Following 3 Users Say Thank You to sshole For This Useful Post:
Ralph Spoilsport (04-08-2014), Wally86 (03-30-2022), ZionsWrath (04-08-2014)
Old 04-08-2014, 01:09 PM   #6
frslee
Just drive it
Drives: 13' FR-S
I jacked the side of the car several times with regular jack, but the steel seems to hold just fine.
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Old 04-08-2014, 02:58 PM   #7
GTHachiRoku
Big in Japan
Drives: turBRZ
Crap, the bar slipped my mind.
Think I can get away with two jacks and two jack stands?
Old 04-08-2014, 03:05 PM   #8
Ralph Spoilsport
Just do the fronts and rears separately (on a pair of jack stands). Jack using the diffy in the back and front jack point for the front as detailed in the GS thread I linked to.
Four jack stands is a problem anyway unless you have a perfectly level floor to set up on.
The Following User Says Thank You to Ralph Spoilsport For This Useful Post:
GTHachiRoku (04-08-2014)
Old 04-08-2014, 04:05 PM   #9
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Excellent idea, I hate jacking my car with that questionable metal end on my jack.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 04-08-2014, 04:06 PM   #10
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
http://www.flyinmiata.com/index.php?...umber=35-70000
I've had one of these since my Miata days and it does just fine for my BRZ.
disgruntld is offline   Reply With Quote
The Following User Says Thank You to disgruntld For This Useful Post:
nyfries (05-16-2014)
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 08:43 AM
Slight body damage, bottom side below passenger door. Need advice! FR-S Matt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 01-23-2014 08:40 PM
Rock damage on side mid_life_crisis Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 10-08-2013 11:56 AM
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 09:19 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 01:53 AM
