Old 04-04-2014, 05:07 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks
Hi guys,
Here are the results from the dyno test we did earlier this week. Keep in mind that the final custom tune (run 274) is not necessary representative of an OTS map. It is a custom tuned map that has been developed on 93 octane. Over the next few days we will test the tune on 91oct in various conditions and confirm stability before releasing it as an Stage 2 UEL+BPB OTS tune.
So with that very important caveat out of the way, here's a brief summary on our testing results.
Test car is our own shop car (2013 FRS 6MT). Modification include OFT, OFH, single tip cat-back and modified intake duct. Pretty basic stuff. The car was tested on 93oct (not the 91oct that we usually test/develop maps with). 91oct fuel testing will happen over the next few days.
Crawford Billet Power Blocks Overview:
Nicely machined product. You can tell a lot of car has been taken into the design. Right down to how nicely the rubber o-rings seat in the machined groves. Crawford does a lot of machine work with their engine building so this is no surprise.
Installation:
It took me about 1.5hrs to install the BPB. I'm no master mechanic but I'm pretty decent with a wrench. It is a 2 person job since a second set of hands is required to lift the manifold upwards while you slide the BPB in place. Also, much care must be taken to not drop anything in the intake ports. So I don't think it's a job for a novice. If you are not mechanically inclined, expect to pay 3hrs of labor to acquire the help of a competent friend who can turn a wrench.
Dyno Results:
First thing we did is test the car with and without the BPB installed. These were done on two separate days but conditions were very similar. The car was even running on the same time of fuel. The car was running the v1.58 Stage 2 UEL OTS map:
With (runs 250 and 251) and without BPB (241 and 242) -No custom tuning-
The results fall nicely in line with intake manifold design theory. The longer runner length compresses the power band so that the power dips and peaks in the happen at lower engine speeds. There is no such thing as a free lunch and this is a good example. Peak power is the same but you have nice solid 10-11whp gains between 6000-6500rpm. Peak power occurs 500rpm lower which means that you can effectively drop fuel cut to just 7000rpm. This means less wear and tear and improvement drivability from not having to rev the engine out to 7500rpm for best performance. I also dropped the shift light trigger by 500rpm.
The downside is that the compressed power curve reveals top end roll off in power (as one would expect). But the gains seems to offset the losses while providing better drivability so it's still a worthwhile bolt-on upgrade for most people who don't necessarily drive at redline.
Custom Tuning Progression
Since the addition of the BPB compress the volumetric efficiency profile of the engine, it would make sense that additional tuning will result in more power. So this is exactly what we did. Over the next few hours we experimented with different VVT, fuel and ignition advance mapping. The latter making the biggest improvements to top end power. It makes sense that the reduced VE in the 6700-7500rpm range would mean lower mean cylinder pressures. Which would allow us to run more advance safely. Everything seemed fine on the dyno. No hint of knock running on 93 oct fuel. And more and more top end power:
Final Custom Tune (with BPB) vs OTS Stage 2 UEL Map (without BPB):
The custom tuning certainly paid off! We restored most of the top end lost by adding the BPB while still retaining the big gains it provided in the critical 5500-6500rpm range.
On The Road..
It feels great! Even though peak power remained about the same, having it come in 500rpm earlier adds some much needed ummph to the FA20. Now you feel a very obvious power bump as you rev out the engine. Very enjoyable on the road. Exhaust note is slightly more pleasant as well. For $400 or ($320 for our OFT customers), it's a no-brainer.
I'll update this thread in a few days with 91oct testing. Once that is done, we will finalize the OTS maps for the BPB and post them online for our OFT customer
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following 56 Users Say Thank You to Shiv@Openflash For This Useful Post:
3essess (04-05-2014), 86-tundra (04-05-2014), akahenry (04-05-2014), BigHugeFatGuy (05-20-2021), Boofneenee (04-04-2014), Carlitoz3 (04-04-2014), Chimera (04-04-2014), clintavo (05-11-2014), coolaron (04-06-2014), Crawford Performance (04-04-2014), Createddeleted (04-04-2014), D-VO (04-12-2016), Deathreaper (04-05-2014), Defpo (07-20-2015), Dimman (04-04-2014), FJ/BRZ (11-08-2014), flippy (12-30-2014), FrsDuke (04-04-2014), fstlane (04-04-2014), gabeg86 (04-08-2014), gramicci101 (04-04-2014), Grymm86 (04-05-2014), GT86meMR2 (04-04-2014), Hagbard (04-04-2014), hamzam (04-18-2014), hmong337 (04-04-2014), illmatic (04-05-2014), immaculate (04-05-2014), J.C. (04-04-2014), jeebus (04-04-2014), Jive Turkey (06-04-2014), jliongh (10-02-2016), Jmonty (04-04-2014), JonAvalon (04-04-2014), Krispeee (04-04-2014), Kronos (04-07-2014), leicaboss (04-04-2014), mad_sb (04-05-2014), makinen (04-04-2014), Malt (04-30-2014), Mike86 (04-06-2014), mission2toilet (04-05-2014), mrk1 (04-04-2014), nor cal frs (10-03-2014), Readytoxplod (04-06-2014), RehabJeff86 (04-14-2014), ripper (07-25-2014), s2d4 (04-04-2014), Superhatch (04-04-2014), Tatsu333 (05-28-2022), troek (04-04-2014), vynervt (04-06-2014), Walla Walla (04-04-2014), Wepeel (04-04-2014), Xinshadow (04-07-2014), YMAA (04-05-2014)
Old 04-04-2014, 05:37 PM   #2
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
This is just great!
so, should we assume that if your new tune is not safe with 91 oct, you will work on a different tune for 91, so we do not lose top end power and still play it safe? (still, we dont seem to lose that much)
edit: could not wait anyway... ordered.....
Walla Walla is offline   Reply With Quote
Old 04-04-2014, 05:41 PM   #3
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Thanks Shiv!
leicaboss is offline   Reply With Quote
Old 04-04-2014, 05:47 PM   #4
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
That 93 Tune looks great! Would this agressive tune work on our 98 Octane fuel we have here?
GT86meMR2 is offline   Reply With Quote
Old 04-04-2014, 05:52 PM   #5
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
anyway to get the 93 tune? did any vvt changes prove usefull? i edit the maps you give us quite aggressivly with timing and fuel. this nj fuel is great, no knock
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following 2 Users Say Thank You to Grip Ronin For This Useful Post:
fstlane (04-04-2014), Gilwith1l (04-04-2014)
Old 04-04-2014, 07:40 PM   #6
jeebus
I'd love to see e85 dynos of this.
jeebus is offline   Reply With Quote
The Following 2 Users Say Thank You to jeebus For This Useful Post:
Luckrider (04-08-2014), Superhatch (04-04-2014)
Old 04-04-2014, 08:43 PM   #7
troek
troek's Avatar
Drives: 2012 Toyota 86
dang, looks pretty good!
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Crawford Performance (04-05-2014)
Old 04-04-2014, 09:21 PM   #8
cplabaunza
I second that...
Darn, I bought them through the FB Group Buy...Guess I'll save my OFT Dollars for the next upgrade
*Red 2014 SRT Viper GTS
*Whiteout 2013 Scion FR-S(SOLD)
*Cyber Grey Metallic 2012 Chevrolet Volt(SOLD)
*Black 2010 Victory Cross Country
*Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6(SOLD)
cplabaunza is offline   Reply With Quote
The Following User Says Thank You to cplabaunza For This Useful Post:
raven1231 (04-04-2014)
Old 04-04-2014, 10:08 PM   #9
Crawford Performance's Avatar
Drives: 2008 STI
Thanks for putting in the time and effort to test your products with our Billet Power Blocks Shiv, love the results!
Crawford Performance is offline   Reply With Quote
The Following User Says Thank You to Crawford Performance For This Useful Post:
Strife26 (12-08-2017)
Old 04-04-2014, 10:53 PM   #10
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
I assume E85 will be an option with these? Please
Proof is offline   Reply With Quote
Old 04-04-2014, 11:05 PM   #11
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Sorry e85 eats this specific type of aluminum, thanks a lot corn farmers!!!
Given Shiv's love for power I have absolutely no doubt there will be e85 maps eventually.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following 2 Users Say Thank You to FrsDuke For This Useful Post:
Proof (04-05-2014), Strife26 (12-08-2017)
Old 04-04-2014, 11:06 PM   #12
Victor Draken
Drives: Toyota Gt86
Where are EL maps test?
I feel srsly left behind in maps development as I have an EL Header.
It's not nice... I will probably switch to another tuning solution if EL ppl don't get same support of UEL ones soon
Victor Draken is offline   Reply With Quote
Old 04-04-2014, 11:12 PM   #13
Shiv@Openflash
Drives: 2013 FRS
EL maps will be released at the same time as UEL maps. We have not shown any favoritism between the two so I'm not sure what you are concerned about. There are just as many EL maps as there are UEL maps.
E85 maps will be released as well . Things take time to do correctly folks. Our maps are thoroughly tested in a number of cars, in many conditions, before they are released.
The Following 10 Users Say Thank You to Shiv@Openflash For This Useful Post:
86-tundra (04-05-2014), 8686 (04-06-2014), cplabaunza (04-04-2014), DAEMANO (04-05-2014), hmong337 (04-05-2014), Lemar58 (04-24-2014), Mike86 (04-06-2014), raven1231 (04-05-2014), Strife26 (12-08-2017), WRB5titch (04-07-2014)
Old 04-04-2014, 11:20 PM   #14
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
All we need now is some DIYs
Carlitoz3 is offline   Reply With Quote
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 03:19 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
Tales from the Dyno: UEL E85 power Shiv@Openflash Engine, Exhaust, Transmission 20 01-20-2016 08:58 AM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
