Old 02-21-2014, 01:14 PM   #43
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
so does this damage the led lights by giving them less juice?
and i want to avoid the soldering part. are there any places i can buy the resistor with the wires attached?
also, the higher the resistor, the lower the brightness?
i've heard some of you say you added more resistors so you could add and remove to adjust the brightness. This is not a plug and play adjustment, right? Technically, you would have to resolder the points if you added more resistors?
subiestyle is offline   Reply With Quote
Old 02-27-2014, 07:01 PM   #44
subiestyle
subiestyle's Avatar
what would happen if you connected wires 1 and 5 without a resistor in between?
would the leds light up 100% with headlights on?
Old 03-03-2014, 12:14 PM   #45
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
I'm no expert and might not be 100% right but I’ll try to provide some info:
Yes the higher the resistor the lower the brightness. Imagine the resistor as a dam and the power as flow of water. The higher the resistor the more the dam is lowered (raised?). So less water is flowing.
Soldering isn't that difficult. Youtube a few videos.
I wouldn't just connect #5 and #1 with a wire without a resistor or diode. Limiting the power to the led will not harm it, but giving it more power then it can handle will. Placing a diode there will also stop the power from flowing back to the HID when your drl is on.
If anybody with more expertise could chime in that would be great.
Zen86 is offline   Reply With Quote
Old 03-25-2014, 01:24 AM   #46
PEWPEW
PEWPEW's Avatar
Drives: 10 Series FRS
You could check this out: http://www.ft86club.com/forums/showthread.php?t=44066
PEWPEW is offline   Reply With Quote
Old 03-26-2014, 09:47 AM   #47
FRS_Sovereign
Manual Noob
Drives: 2013 Scion FR-S MT Asphalt
Winjet Headlights
Will this set up work for winjet lights as well. I don't want to buy a $50 resistor from fteightysix if I don't have to.
FRS_Sovereign is offline   Reply With Quote
Old 05-24-2014, 01:52 AM   #48
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
alright, i picked up a pack of the resistors off of amazon, but where can i get the diodes seen in the pic below to do the installation?
zAnSh1n is offline   Reply With Quote
Old 05-24-2014, 02:05 AM   #49
Zen86
Run, Reach, Fly
Zen86's Avatar
^ radioshack
Old 05-24-2014, 02:08 AM   #50
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
there are no ratings for the diodes? i just get a pack of any diodes?
edit: i see 1amp, 3amp, etc... which one do i need for this DIY?
Old 05-24-2014, 09:55 PM   #51
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
so from the pic @Luis_GT posted, im going to guess this is the diode i need?
http://www.radioshack.com/product/in...lue=RadioShack
please confirm, thanks.
Old 05-24-2014, 10:29 PM   #52
Luis_GT
Should work as long as it can hld 12 volts
I used this one to be exact
http://www.radioshack.com/product/in...ductId=2062579
The Following User Says Thank You to Luis_GT For This Useful Post:
zAnSh1n (05-24-2014)
Old 06-04-2014, 06:46 PM   #53
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
alright, i am ready to put it together and install...
but before i do, please confirm that this is correct, thanks:
The Following User Says Thank You to zAnSh1n For This Useful Post:
LXXXV1 (06-24-2015)
Old 06-04-2014, 06:54 PM   #54
Zen86
Run, Reach, Fly
Zen86's Avatar
Looks right. But if it doesn't work after install just flip the connecting wires around.
Old 06-08-2014, 12:50 AM   #55
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
ready to install... it's ok that i shrink wrapped the solder points, right ?
tigermack (12-27-2014)
Old 06-08-2014, 01:17 AM   #56
Zen86
Run, Reach, Fly
Zen86's Avatar
Yep that's fine
The Following User Says Thank You to Zen86 For This Useful Post:
zAnSh1n (06-08-2014)
Installed 10 Series Headlights Today Calavera Cosmetic Modification (Interior/Exterior/Lighting) 58 02-15-2024 03:18 PM
Scion 10 series headlights gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 19 04-20-2014 11:26 PM
86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV Calavera Cosmetic Modification (Interior/Exterior/Lighting) 42 08-21-2013 06:54 AM
GT86 European headlights ? rikdrt1 Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2012 04:32 AM
European delivery date ? Sylvain44 BRZ First-Gen (2012+) — General Topics 6 06-04-2012 07:27 AM
