Old 03-24-2014, 10:20 AM   #1
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Pick 2 gauges for turbo build.
I will be able to mount 3 gauges (1 AC vent and 2 defroster pod) when I do FI for the first time in my life next month. I will be running an AEM wideband failsafe in one of the spots. Not quite sure which are the next two most important gauges to mount for this application.
1. Oil Pressure
2. Oil Temperature
3. Coolant Temperature
This is probably a noob question but any help would be appreciated.
Cheeseballs is offline   Reply With Quote
Old 03-24-2014, 10:23 AM   #2
OrbitalEllipses
Drives: Attitude
AFR/boost combo gauge, then oil pressure and/or temperature.
The Following 6 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (03-24-2014), Cheeseballs (03-24-2014), Dream20b (12-03-2014), Hawaiian (03-24-2014), hmong337 (12-02-2014), OjiGeorge (03-24-2014)
Old 03-24-2014, 10:24 AM   #3
Ross
Drives: 85 corolla gts
http://www.innovatemotorsports.com/products/MTXD.php
they have a dual gauge for oil temp and pressure, then from there egt would not hurt.
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
1stGenBRZ86 (03-26-2014), Cheeseballs (03-24-2014)
Old 03-24-2014, 10:25 AM   #4
mrk1
Drives: Sterling BRZ Ltd
this
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 03-24-2014, 10:26 AM   #5
OrbitalEllipses
Drives: Attitude
Solid advice from @Ross. Boost/AFR, Oil T/P, EGT...you're now monitoring the most vital things you need to monitor.
Old 03-24-2014, 10:30 AM   #6
Cheeseballs
Drives: Really slow
Thanks for making it an easy decision for me.
Old 03-24-2014, 10:35 AM   #7
OrbitalEllipses
Drives: Attitude
FYI @Cheeseballs EGTs can be tricky since you need to have a bung for the thermocouple - are you still on the stock header? Stock header will require drilling/welding a bung to use EGT whereas most aftermarket headers (of quality) come with at least one bung, if not more. Unless your gauge can accommodate four sensor inputs, you're going to want to put the sensor in the hottest exhaust runner; traditionally for the turbo Subarus this has been the runner from the #4 cyl, though I can't with any veracity make that claim on this engine.
Cheeseballs (03-26-2014)
Old 03-24-2014, 10:47 AM   #8
mike the snake
I'm getting PLX gauge, which either plugs into your car's OBD port, or you use their modules for whatever you want to monitor.
Each gauge can show a bunch of different hings, you just scroll through to whatever you want to view.
http://www.plxdevices.com/product_info.php?id=MULTDM6
Old 03-24-2014, 12:21 PM   #9
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
innovate oil pressure/temp combo gauge, innovate water temp, aem failsafe afr/boost,
Old 03-24-2014, 12:40 PM   #10
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
IMO
AEM Failsafe, EGT gauge and an oil pressure.
Temp is important, but not quite as important as your pressure suddenly falling off the map.
Again, IMO.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-24-2014, 01:17 PM   #11
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I went with 2, the AEM failsafe and Innovate MTX-D for Oil Pressure and Temp in 1 gauge. If I were forced to pick a 3rd gauge, it would be water temp
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-24-2014, 01:25 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The OEM water temp sensor in your gauge cluster is effective enough. I might go with a fuel pressure one if I was running a heavily modified fuel system or a high boost setup that taxed the fuel pump.
Calum (03-24-2014)
Old 03-24-2014, 01:27 PM   #13
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
When this goes in to production in the next couple of months it will be an excellent option. AFR, Boost (up to 44psi), boost control, boost cut by RPM and/or AFR, programmable shift light, and 0-5v analog output for AFR. You can also log solenoid duty cycle, manifold pressure, AFR and engine RPM to your laptop or iPhone provided you use it in conjunction with the OT2 device. You can also daisy chain this device with our other MTX-D series gauges to also log your oil pressure, oil temp temperature, etc. A ton of functions for a single gauge.
mines13 is offline   Reply With Quote
The Following 2 Users Say Thank You to mines13 For This Useful Post:
Cheeseballs (03-26-2014), Hawaiian (03-24-2014)
Old 03-24-2014, 02:20 PM   #14
OrbitalEllipses
Drives: Attitude
Originally Posted by mines13 View Post
[product description]
Logging from ODBII port?
Just Another (Turbo) Build rb6freak Member's Car Journals 184 03-22-2017 09:25 AM
Do Boy's Turbo FR-S build!!! Do Boy Member's Car Journals 417 11-29-2015 02:17 AM
Turbo Kit & Shop Car Build Carolina Dyno Forced Induction 11 01-22-2014 03:59 PM
pick-a-turbo for beginners! subatoy Forced Induction 20 07-25-2013 07:09 PM
Gauges for Turbo, boost controller options? gdrider77 Forced Induction 27 05-13-2013 06:57 PM
