Old 03-04-2014, 02:15 PM   #1
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
RPM varies, cold start, clutch in and out
I've been looking on here for awhile and I haven't seen anyone else talk about this. When I start my car cold in the morning the RPMs vary in neutral depending on if the clutch is in or out. RPM goes up slightly with the clutch in and goes down slightly with it out. Its maybe around a 50-100 rev difference. When warm I don't notice anything, seems to be mainly during the fast idle period. Just wondering in case my clutch is out of adjustment or if its just something the car is programmed to do for whatever reason.
00NissanNinja is offline   Reply With Quote
Old 03-04-2014, 02:42 PM   #2
z3ro
mine does this to but i think its just because with the clutch out there might be slightly more load on the engine.
Never seen any adverse effects so i'm not concerned but i'd still like to see a more technical response.
z3ro is offline   Reply With Quote
The Following 3 Users Say Thank You to z3ro For This Useful Post:
00NissanNinja (03-04-2014), humfrz (03-04-2014), strat61caster (03-04-2014)
Old 03-04-2014, 03:01 PM   #3
00NissanNinja
The Thread Lurker
Cool thanks. I haven't seen any issues either. I too wonder the technical reason for it.
Old 03-04-2014, 05:08 PM   #4
I think z3ro nailed it up above .....
Old 03-04-2014, 05:42 PM   #5
Porsche
Drives: 2013 BRZ Ltd. MT
When I start my car cold in the morning the RPMs vary in neutral depending on if the clutch is in or out. ... RPM goes up slightly with the clutch in and goes down slightly with it out.
Even when the gearbox is in neutral, if the clutch is engaged (foot off the pedal), the engine is spinning the gearbox input shaft at engine rpms, which in turn has ALL OF THE GEARS spinning at their respective rpms. In neutral, of course, the output shaft has not been engaged, so the drive wheels are not being driven.
This is strictly speculation, but my first guess is that when the clutch is engaged, with all the gears being spun in the cold, and relatively thick, bath of transmission oil, there's real resistance there to be overcome when the trans is cold.
De-clutch and that drag on the engine from the transmission is now removed, and so the rpms edge up a little.
When the transmission oil heats up, it creates less drag, so you don't notice it much, then.
Do I get a prize?
Porsche is offline   Reply With Quote
The Following 5 Users Say Thank You to Porsche For This Useful Post:
00NissanNinja (03-04-2014), BRZ21 (03-04-2014), DarkSunrise (03-04-2014), Gords_zenith (03-04-2014), z3ro (03-04-2014)
Old 03-04-2014, 06:34 PM   #6
z3ro
Do I get a prize?
Swift kick in the nuts work because thats about all I have right now :0)
Sent from my SCH-I545 using Tapatalk
Old 03-04-2014, 07:19 PM   #7
Even when the gearbox is in neutral, if the clutch is engaged ...........
Do I get a prize?
Well, no, ....... ol @z3ro made that discovery up in post #2.
However, you do get recognition for your excellent explanation .....
Old 03-04-2014, 10:42 PM   #8
00NissanNinja
The Thread Lurker
Do I get a prize?
Nice and logical just the way I like it. I did not think even think to consider the resistance of the oil. Makes a lot of sense considering how viscous gear oil is.
Alright, I'll come by your place and do some donuts how bout that as a prize haha.
Old 03-04-2014, 11:40 PM   #9
Porsche
Cool!
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Rubber smell sometimes on cold start jonbonazza Issues | Warranty | Recalls / TSB 9 12-04-2013 05:32 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
