Old 03-01-2014, 08:30 PM   #1
2isballer
Drives: 2014 Scion FR-S
Diode Dynamics Switchback Turn Signals LED
My order for the switchback LED's, HID kit, and dome light came in today from Diode Dynamics. Everything went fine except the switchback LED is too big and won't fit through the socket into the housing... Anyone have a problem with this????
2isballer is offline   Reply With Quote
Old 03-01-2014, 08:58 PM   #2
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
no they will fit, i had the same issue what you have to do is you gotta keep twisting it around into the hole in a straight direction dont be afraid to give some pressure pushing it in while twisiting and u will find the spot.
914_WHITE_FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to 914_WHITE_FRS For This Useful Post:
2isballer (03-02-2014), DAEMANO (01-26-2015)
Old 03-02-2014, 01:46 PM   #3
2isballer
thanks for the help! Turn it and putting it in at a certain angle helped. Just gotta play with it a little bit. Hope I don't have trouble getting it out!
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
Spring Cleaning: Lighting, Lug Nuts, Stock Exhaust and Suspension CreinCrein Canada Classifieds 17 04-17-2014 06:08 PM
Switchback led turn signals installation Scionshaun Cosmetic Modification (Interior/Exterior/Lighting) 1 05-24-2013 06:31 PM
Request - 5000k LED Switchback Turn Signals raul Cosmetic Modification (Interior/Exterior/Lighting) 8 03-07-2013 06:50 PM
Are Switchback Turn Signals Legal? i_4got CANADA 7 11-03-2012 05:47 PM
