Old 01-26-2014, 11:38 PM   #1
mtsui
Drives: 135i
Tein SRC rebound and compression set up for track
Hey guys,
I went to the track with the SRC today and I'm having some difficulty to fine tuning it. Right now, I think its worst than OEM setup and running slower time
I was wondering if you guys can share some of your rebound and compression set up, so I have an idea of how to start?
Also, for the SRC, which knob is for rebound and which knob is forcompression?
mtsui is offline   Reply With Quote
Old 01-27-2014, 12:36 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
These are some general settings with 10k front, 12k rear springs.
Adjustments are made starting from the stiffest setting, clockwise all the way, and then turning back until the adjustment knob settles into the first groove. This first groove or click is "0". Each click from here increments the setting by 1.
All setting are in the following format: front compression/front rebound, rear compression/rear rebound.
track: 5/6, 5/6
"looser" track setting: 5/6, 7/7
"tighter" track setting: 6/6, 5/6
Canyon: 7/7, 7/7
Daily/comfort: 8/9, 9/10
My personal preferences are 5/6, 5/6 on track, and 7/7, 7/7 on the street (all the time).
Old 01-27-2014, 12:57 AM   #3
CSG Mike
CSG Mike's Avatar
Which FRS/BRZ were you in?
Old 01-27-2014, 01:08 AM   #4
mtsui
Drives: 135i
white frs number 11, the car was jumping around, some understeer and oversteer, but maybe because the tires is in really bad condition tho.
Old 01-27-2014, 02:54 AM   #5
mtsui
Drives: 135i
I saw and its too stiff for me, so wanna see how other people setting is
Old 01-27-2014, 03:21 AM   #6
CSG Mike
CSG Mike's Avatar
I think you briefly followed me for a bit; I was in the CSG car at the time, but I was hopping around in a few different cars between setup and some instruction.
What settings are you on? If you'd like to have us dial in your SRCs in for you, PM me for rates.
Old 02-27-2014, 12:13 AM   #7
dp1
driving smoother faster
Drives: Sold
Hi there, did you get this resolved with CSG? Outcome? Thx
dp1 is offline   Reply With Quote
Old 02-27-2014, 03:43 AM   #8
mtsui
Drives: 135i
no, just gonna try it by myself.
Old 02-27-2014, 09:29 AM   #9
dp1
Drives: Sold
Which settings did you try? Did you purchase the Teins new, where, and did they come with recommended settings? Did you make any other suspension changes? Camber/caster/toe? Tires? Wonder what made it not work for you. Thx
Old 02-27-2014, 01:11 PM   #10
CSG Mike
CSG Mike's Avatar
We're always here if you need help
dp1 (02-27-2014)
Old 02-27-2014, 08:23 PM   #11
mtsui
Drives: 135i
i only have 1 track day on them, of coz needs time to adjust myself. so i cant say its not working for me, just need time.
Old 02-27-2014, 08:29 PM   #12
dp1
Drives: Sold
Ok, hope you consider the offer from @CSG Mike to get everything dialed in properly...it appears to be a pretty capable set
Old 02-27-2014, 08:30 PM   #13
CSG Mike
CSG Mike's Avatar
From a cost perspective, doing 1 track day costs more than paying us to dial them in for you :p
The SRCs are plenty capable; we've run sub-2 with them, NA
Old 02-27-2014, 08:36 PM   #14
mtsui
Drives: 135i
I just wanna see and compare other people set up. I like to learn as Im driving it. its no fun to have everything set up by someone or maybe its not even suit my style, everyone has a different driving style.
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
Adjustion compression on a Koni 8612 insert? Evil86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-05-2013 05:01 PM
queston about low compression pistons on stock ECU clayrush Engine, Exhaust, Transmission 1 12-03-2012 11:11 PM
