Old 02-15-2014, 09:49 AM   #1
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Cam timing adjustments without dyno
Is it viable to make cam timing changes when road tuning?
Doesn't look like any local shops have experience with this platform so I might be SOL.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-15-2014, 10:02 AM   #2
mad_sb
Drives: 2013 Asphalt FR-S
Very difficult to do any more than rough tune the cam settings unless you have a perfectly repeatable section of road to use for logging.
Once your in the ball park, the power variations with minor changes will be well within the error range for run to run variation. My suggestion is to get fuel and timing dialed on the road then go to the dyno to do cam timing and then touch up fuel and timing, if you are trying to save dyno time that is. Or better yet, start with a base map that is close to your setup.
Whats your parts list? If your stock then just use one of the oft basemaps and don't worry about dyno time.
The Following User Says Thank You to mad_sb For This Useful Post:
arghx7 (02-15-2014)
Old 02-15-2014, 11:24 AM   #3
StormTrooper
Perrin filter and inlet hose, nameless DP catted and resonated, Nameless header here soon. Possibly the axle back with an extra resonator.
I will probably start with the OFT EL stg2 map but I'm sure the cam timing will be different.
I'm at 4500' so my fuel and base timing will be off as well.
GR86 MT premium
Old 02-15-2014, 03:41 PM   #4
jamesm
i have a very simple method of tuning cams, whether on the road or otherwise. not very scientific, but it works.
log a few pulls... calculate ve... make a change... if it improved ve do more of that, if not do the opposite. with sd it's even easier... just don't change your ve map and see where you go lean/rich. fix the ve there to get the afr back in line the do more of the same.
The Following 3 Users Say Thank You to jamesm For This Useful Post:
Ironsquid (02-18-2014), vynervt (02-15-2014), Yobiwan (02-19-2014)
Old 02-15-2014, 07:02 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
I started this thread last week:
http://www.ft86club.com/forums/showthread.php?t=57662
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-15-2014, 07:41 PM   #6
StormTrooper
Originally Posted by Kodename47 View Post
How do you go about adjusting the timing... In groups like the stock is setup or individual load cells?
GR86 MT premium
Old 02-15-2014, 07:56 PM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you have a good basemap I'd just look at full throttle changes and then smooth out the map. Doing partial throttle just won't be possible on the road.
If Shiv's maps are the same as the others I've seen, the top load cells are the same throughout the RPM range.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-15-2014, 07:59 PM   #8
StormTrooper
I haven't looked at them.... Not real good with the program yet
GR86 MT premium
Old 02-17-2014, 06:55 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's my post with stock vs OFT:
http://www.ft86club.com/forums/showp...0&postcount=19
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-18-2014, 01:30 PM   #10
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Done my homework, 2 questions :
1 - I got a higher value of 123% of VE at 4083RPM, and most of the time over 100% : not bad for a NA ! Are my numbers right ?
2 - Load curve is quiet similar to VE one, is it a good approximation ?
I have a simple formula to calculate VE approximately for NA in metric :
VE approx = ( MAF / 1.2 ) x 60 / RPM
MAF = mass air flow (gram/s)
/ 1.2 = 1 liter of air weight 1.2 gram at 10°C
* 60 to convert in minutes -> real number of liter inhale / mn
/ RPM (cause a 2 liter engine theoretical deplacement is 1 liter / round !)
On the graph, VRE with complicate formula for pressure correction, VRE approx describe below, and load comparison
https://drive.google.com/file/d/0B2J...it?usp=sharing
banane63 is offline   Reply With Quote
Old 02-18-2014, 02:00 PM   #11
jamesm
123% seems a bit extreme for an na car.
Old 02-18-2014, 02:05 PM   #12
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
123% would be really hard to do, that's like giant air funnel snorkeling in volumes of air to your intake, WS6 Ram-Air style.
Ironsquid is offline   Reply With Quote
Old 02-18-2014, 02:18 PM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
Some smart arse gave me this formula to use to calculate VE:
[MAF in g/s] / (([MAP in kPa] x 1000)/(287.05 x ([IAT in C] + 273.15))x1000))/(121.9254 x [RPM]/3456x0.0283/60)x100
MAP can easily be converted from bar to kPa by multiplying by 100 if that's all you've logged.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-18-2014, 03:00 PM   #14
jamesm
Just check to confirm that all the input data is reasonable. I.e. You didn't have one NaN cell for iat or something.
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 03:18 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 05:56 AM
Can we add the adjustments-lever on passenger side SEAT ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 1 01-28-2013 10:22 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 09:10 PM
Pedal Adjustments? djliquidsteele Engine, Exhaust, Transmission 3 06-09-2012 10:43 AM
