Old 01-24-2014, 05:46 PM   #1
Hachiroku14
Drives: 2014 BRZ World Rally Blue
DIY Rear Backup Camera on Bumper (small)
Here's another option for the reverse camera which I think has a less obtrusive look with that OEM feel.
Supplies needed:
$20 Camera: http://amzn.com/B00H3ZN3JK (the 0.50" non-guideline version is what I should've gotten or else you will have two guidelines showing on screen like mine)
Soldering iron
Electrical tape
Plastic adhesive
3/8" Rubber Grommets
1/4 - 3/8" drill bit
Blade cutter or dremel
16-20 gauge wire (the thinner the better)
Screw driver
10mm socket with extension
Female pin connector 2.54mm OR http://ae64.com/Rear-camera-16-pin.htm
8mm socket (optional)
Painter's tape (optional)
Here's what it should look like when done:
PLS REMOVE BATTERY (-) TERMINAL BEFORE PROCEEDING
Let's get started: Additional pics courtesy of ft86 members
There are 3 wires that we need to deal with.
Wire 1: Trigger Wire - from head unit to reverse light switch (+) on the ECU
Wire 2: Camera (+) - from camera to any (+) source except the reverse camera (+)
Wire 3:
Video cable - from camera - to head unit
You can also buy this to make it way easier http://ae64.com/Rear-camera-16-pin.htm so that you don't need to splice the Video cable.
STEP 1 : REMOVE HEAD UNIT - http://www.ft86club.com/forums/showt...ght=rydeen+duo
STEP 2: CONNECTING THE WIRES FROM HEAD UNIT
VIDEO CABLE:
Option 1 - if you are using this harness (which I suggest you do if you don't have a bit of electrical background) http://ae64.com/Rear-camera-16-pin.htm then just proceed with the link above until you finish wiring the 16 pin connector
Option 2 - cut and splice the MALE end of the video cable to give you a small yellow wire and a ground wire beside it. Now you have two options:
1. Solder each wire and insert in the connector as pictured below ( not recommended but have done it and it worked)
OR
2. Have these on hand (which I happen to have) http://amzn.com/B00CGWVFWW and use it to pin to the existing connector on head unit
Another view of connector and where the video wires are supposed to go:
Yellow wire - #8 pin
Ground - #16 pin
TRIGGER WIRE:
We first need to remove the under dash panel
Pull and unclip starting here
Remove the screw
Another screw near knee pad side then you can un-clip the panel starting from the bottom. Then unplug the connectors to fully release the panel.
Now connect a wire from the head unit going behind the steering wheel column to the ECU harness as shown below:
Head unit side
ECU side (remove connector and tap wire to Red/Blue reverse light wire)
Now run the video cable from head unit to trunk ( This is the path I took: head unit - under dash - drivers side running board panel - left rear passenger panel - trunk)
WE'RE HALF WAY THERE!!
CAMERA POWER (+) (-) WIRE:
For this one I decided to use the (+) Amplifier power so the camera is powered only when car is on.
Using the camera power harness, I connected the camera's RED wire to the amplifier's GREEN wire (+). And the black wire to the stock body ground pictured below.
CAMERA INSTALLATION:
OPTIONAL : Remove the tailights to avoid scratching the bumper. I did this to avoid any risk of chipping my paint. Better safe than sorry
REMOVE REAR BUMPER:
http://intranet.toyotaperu.com.pe/td...034ww02xx.html
CAMERA PREPARATION:
Disassemble camera.
Cut rubber grommet in half
OPTIONAL if you can find a better grommet that would fit: Using a blade cutter, notch the inner part of the grommet to make it stretch easier
Fit one of the grommets on the camera, smooth side facing lens.
NOTE: Make sure you put a good adhesive seal around the front and back of the rubber or your camera might not be water proof and it also keeps the lens from spinning
Using a drillbit, make a hole just enough to fit the lens in it. (the center of the bumper is where the groove changes direction)
Using the other half of grommet, secure camera on bumper
NOTE: if outer lens cannot be secured, bumper wall is thick so you need to notch the inside.
Put bumper back (just pop it and but do not put clips) while inserting camera wires through the holes in the bumper brace to the hole in the trunk near the latch. Now the camera is just big enough so that when you put back the bumper, it will get lodged bet. the brace and thus securing it without the need for screws. Connect the camera and test. If angle is wrong, you can slightly pull the bottom part of the bumper, grab the outer lens with grommet and turn it. If everything is aligned, disconnect camera and carefully remove the bumper paying close attention to the wires so that the camera doesn't get tugged. Put a plastic adhesive in the inner part where bumper meets camera just to keep it from rotating. Let dry. Now is a good time to secure all wires and connections. Once adhesive is dry, install everything and go to line diag mode on head unit by pressing (audio+voice) OR (audio+voice+map) whichever shows this screen:
Go to settings and adjust camera as necessary.
ENJOY your new back-up camera!!!!
Hachiroku14 is offline   Reply With Quote
The Following 13 Users Say Thank You to Hachiroku14 For This Useful Post:
Ayoitszritchie (05-14-2014), B-R-Z (07-24-2014), Creole (07-19-2014), illicitstylz (05-12-2014), Jav (07-16-2015), JFBRZ711 (03-21-2014), Khánh (07-09-2014), normancw (01-24-2014), notout86 (08-18-2014), Octoman (07-20-2014), SkAsphalt (02-28-2014), skye67 (07-26-2014), weepel (08-18-2014)
Old 01-24-2014, 06:14 PM   #2
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
That's a good idea @Hachiroku14, I might just do that as I didn't like how the OEM one sticks out.
I'm also thinking, after seeing this, of mounting it on one of the tow hook cover, a bit cheaper to undo.
voyager2285 is offline   Reply With Quote
Old 01-24-2014, 06:20 PM   #3
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
That looks pretty good!
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
Hachiroku14 (01-24-2014)
Old 01-24-2014, 07:19 PM   #4
Hachiroku14
Only issue I see with that is the camera is not centered but maybe you can get away with re-aligning the guide lines.
Old 01-24-2014, 10:18 PM   #5
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Looks good, I like guide lines
Jmonty is offline   Reply With Quote
Old 03-15-2014, 09:08 AM   #6
sirisvirus
Drives:
Looks really good I may have to do this mod
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 03-28-2014, 11:35 PM   #7
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Are you going to mount a front camera as well? I love how this looks. Now I just need to find a reputable shop to put this together.
Chad86 is offline   Reply With Quote
Old 03-29-2014, 12:56 AM   #8
2nd Gen Scion
Drives: Scion FR-S Manual Raven Monogram
Does the software come with the camera?
2nd Gen Scion is offline   Reply With Quote
Old 04-01-2014, 03:06 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
no software need
Old 04-02-2014, 06:33 AM   #10
2nd Gen Scion
Would this not be easier for people to mess up as well? I mean I completely understand not wanting to mess with the body of the exterior of the car, I'm skeptical myself. Having it in the tow hook panel makes me think that IF people were to mess with it they'd be more inclined to if it was there. If you put it in the center of the bumper like in this post it looks factory unless you stare at it, and, imo, has a less of a chance to be messed with.
I'm a big fan of symmetry, how would it'd look in the head unit? wouldn't the off-center/lower position of the camera be a nuisance at best?
Old 04-02-2014, 10:53 AM   #11
djdnz
1337
Drives: 2013 BRZ WRB S/C
Wow nice job. Would the camera fit in the depressed section just above where you mounted it?
This is tempting!
djdnz is offline   Reply With Quote
Old 05-12-2014, 05:22 PM   #12
A3r0pusH
A3r0pusH's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Would this work on an FRS with the pioneer head unit?
A3r0pusH is offline   Reply With Quote
Old 05-12-2014, 05:42 PM   #13
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
I plan on running both a front and rear camera on my FRS but I need to figure out the best way to setup the front camera. Depending on what headunit I purchase, I may run it to that if it has extra connections for it, or just get a mini screen and mount it some place where it will look clean.
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 05-13-2014, 01:15 AM   #14
Chad86
Chad86's Avatar
Drives: Toyota GT86
Let me know what you decide to do. I'm not sure where the front camera should go. I would like to do this myself, but I will probably get it professionally done.
Fs: Beat-Sonic BCAM7 Rear Backup Camera (New) ucsmfu Canada Classifieds 2 01-29-2014 07:00 PM
Fs: Beat-Sonic BCAM7 Rear Backup Camera ucsmfu Audio/Visual, Electronics, Infotainment, NAV 0 01-09-2014 10:45 AM
Fs: Beat-Sonic BCAM7 Rear Backup Camera ucsmfu Canada Classifieds 0 01-05-2014 06:20 AM
Bluetooth Backup camera Zardoman Northern California 4 08-22-2013 04:05 PM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
