Old 12-21-2013, 01:23 AM   #1
Nicolas0esp1
Nicolas0esp1's Avatar
Drives: Stock Scion FRS
Removing The Resonator
So someone told me to remove the intake resonator because it will make my car sound better and also be less restrictive... Is it bad for the car? I herd i could also lose HP? I wanna do it but IDK how and what so if someone could tell me what to do that would be most appreciated
Nicolas0esp1 is offline   Reply With Quote
Old 12-21-2013, 03:11 AM   #2
Well, Nicolas0esp1, the way I figure it is, that if by removing it, had benefits ..... why did the manufacturer put it there in the first place .. ??
ddevl_86 (03-30-2021)
Old 12-21-2013, 03:43 AM   #3
diss7
Drives: AE86, 2x GT86, TE27
Because the manufacturer has to worry about so many things, things that we might disagree with.
They have to worry about noise pollution. From the exhaust and intake.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Old 12-21-2013, 04:38 AM   #4
350matt
Drives: toyota mr2/ Toyota GT86
the large resonator on the airbox is very likely going to give a positive effect
however the only way to find out is to do a proper test on some rollers with an optimised tune for both runs
as we've seen that the MAF meter is very sensitive to anything in front and after it and as the car runs too rich to begin with quite often a go faster intake is merely leaning things out
post your result up here so we can all have a look
350matt is offline   Reply With Quote
Old 12-21-2013, 08:48 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
I did it ages ago and posted my findings. The MAF gets very noisy at low RPM without it and made the engine go lean. It felt worse so I put it back on.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-21-2013, 09:17 AM   #6
tennisfreak
Drives: 2018 BMW M240i
Well if its any consolation the TRD intake removes the resonator and sound tube completely.
If Toyotas own products remove it then it should not be of too much importance.
The resonator and sound tube seem to be ways to make sound and direct it to the cabin for a cool "effect".
Old 12-21-2013, 03:56 PM   #7
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
but the TRD also moves the MAF position...
EvilBeaverFace is offline   Reply With Quote
Old 12-21-2013, 05:33 PM   #8
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
They're usually used to reduce noise, especially the lower frequencies. I'd remove them knowing nothing bad would happen but you never know with the newer cars, it would be interesting to do some quick data logging of the MAF readout before/after. It's probably not alot.
Rayme is offline   Reply With Quote
Old 12-21-2013, 06:42 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
My findings
.: Stealth 86 :.
Kodename 47 DJ:
Rayme (12-21-2013)
Old 12-21-2013, 06:57 PM   #10
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Anf the TRD intake is LARGER, the resonator is still internal space removing it changes the intake tracks length which isnt a great idea....bet the TRD intake is the same internal volume as the stock intake system or damn close
Fett4Real is offline   Reply With Quote
The Following 2 Users Say Thank You to Fett4Real For This Useful Post:
Kodename47 (12-21-2013), tennisfreak (12-22-2013)
Old 12-21-2013, 08:35 PM   #11
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
In putting the Perrin tube from the airbox to the intake I removed all the noise generator and I guess the resonators you are talking about. Ask Perrin!! My car is quiter inside thanks to generator being removed.
DrDuquette is offline   Reply With Quote
The Following User Says Thank You to DrDuquette For This Useful Post:
Old 12-21-2013, 08:39 PM   #12
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
the resonator doesnt help make sound if anything it muffles it
Old 01-22-2014, 02:52 PM   #13
Nicolas0esp1
Tryin to watching this in my car... My subs toooo good lol but i cant hear it that we'll idk if it's my speakers or the mic pos.
delete, intake, monster, resonator, sound
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 08:17 PM
TRD exhaust resonator delete? pcporo Engine, Exhaust, Transmission 19 03-15-2014 10:48 AM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 09:14 PM
Exhaust Resonator Brndn704 Engine, Exhaust, Transmission 3 08-20-2013 02:31 PM
Glasspack or Resonator Delete or ? Yruyur Engine, Exhaust, Transmission 6 02-02-2013 01:13 AM
