Old 11-13-2013, 03:47 AM   #1
arashishozen
Guest
Posts: n/a
Tire brand recommendations
It's that time to buy tires. What brand and type of tire, and mileage do y'all recommend?
Old 11-13-2013, 04:50 AM   #2
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
What size tyre do you want? What purpose? Track? Daily? Winter? All Season? Summer?
Wise is offline   Reply With Quote
Old 11-13-2013, 05:13 AM   #3
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
continental dw!
2013 WRB Subaru BRZ Sport-Tech
-TRD intake
-Perrin 2.5 inch cat-back exhaust
lavisxice is offline   Reply With Quote
Old 11-13-2013, 05:15 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Just get something from tire rack
Old 11-13-2013, 06:28 AM   #5
arashishozen
Guest
Posts: n/a
Im not sure what size to get or what sizes could fit. What size do you recommend? I have stock rims by the way. I suppose daily all season tires, though I dont plan on driving it all the time ( thats what my Bronco is for) Im looking for something that grips pretty well too as I do enjoy spirited rides through the country side.
Thanks.
Old 11-13-2013, 07:09 AM   #6
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Summer tire - Michelin Pilot Super Sports 215/45/17 (or 225 for more meat), both of which will fit just fine on stock rims.
enouf is offline   Reply With Quote
Old 11-13-2013, 07:10 AM   #7
Wise
Circle Work Clerk
Thanks.
225/45/17 Michelin Pilot Super Sports if you've got the cash.
Old 11-13-2013, 07:22 AM   #8
arashishozen
Guest
Posts: n/a
How would Summer tires hold up in the winter and vice versa?
My dd is quite old and who knows when.id have to drive in the snow ,etc and I dont want to.have to buy several sets of tires just to drive it year round. ( unless I drive that much =0 )
Old 11-13-2013, 07:24 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
If you only want 1 set I'd recommend all seasons and stay home when it is actually snowing.
If you are strapped for cash I'd say buy a set of someone OEM wheel (or steelies) and mount General Altimax Arctic winter tires and put them on if you need to drive in the snow.
Old 11-13-2013, 07:30 AM   #10
arashishozen
Guest
Posts: n/a
As a general rule there would only be two occurrences that id have to drive in the snow. A to get to work bc Nissan wont ever shut down and two if it snows when im on vacation during schedule shutdown at nissan.
I live in Tn so as a general rule we dont get much snow. Just mainly the worse of the two evils...black ice
Old 11-13-2013, 10:05 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Don't fixate on brand name. Every major brand makes some good tires, some crap tires. Focus on what your specific wants/needs/usage and pick the best specific tire model for that at the lowest price. www.tirerack.com is your friend. Loads of test info, customer surveys, and reviews. Pay particular attention to WET grip! Plenty of tires that have good dry grip and suck in the wet. You want tires with very good wet grip for a dd street car.
If ultimate performance isn't that big a concern, and you will be driving in the cold months, and the possibility exists that you might have to drive in snow or cold/wet or ice (!!!) conditions, UHP all-seasons are probably the way to go. Although on black ice, god help you in any case :P
No reason not to get OEM size: 215/45-17. But you could also go with 225/45-17 if price is favorable or if the tire that suits your needs best is only available in that size.
Faced with similar demands to yours for my wife's Mazda3, I got General G-Max AS-03 tires a year ago. No complaints!
http://www.tirerack.com/tires/tests/...y.jsp?ttid=151
Old 11-13-2013, 10:09 AM   #12
Suberman
Drives: Subaru BRZ Sport Tech Satin White
If you get black ice the only tire that will work (without metal studs) is a Q or R rated studless winter tire. The stickiest ice tire available is the Blizzak W line of tires. These are awful to drive on and after they are half worn they are no longer fit for winter. However, they are a true ice tire.
I won't put bridgestones on any car of mine but many people like them.
The next tier up which are also decent to drive in are Michelin X Ice, Nokian Hakkapelitta, Continental ExtremeWinter Contact and similar. The General tire recommended is excellent also (General is a Continental subsidiary) and Hankook Ice Bears get good reviews.
Suberman is offline   Reply With Quote
Old 11-13-2013, 10:11 AM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
General altimax arctic is Q rated (99 mph), very soft. No fun in the dry lol
Old 11-13-2013, 11:13 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Why not?
Bridgestone makes some GREAT tires, including the RE11A, S-04, RE970AS, etc.
They also make tires that are UTTER CRAP, particularly the OEM all-season tire for the FR-S/BRZ: Turanza EL400-02 (that tire is probably the only reason we didn't get the wife a new Mazda3 this year).
But *every* manufacturer makes some tires that are pretty much CRAP.
Falling into Brand X vs. Brand Y thinking only increases chances of making a sub-optimal choice. You cannot guarantee a good tire going only by brand, and if you do go by brand you are eliminating a lot of good tires from consideration.
It's critical to know about the *specific tire model* you are considering. You can't just go by brand name or even model line (Bridgestone "Potenza", Goodyear "Eagle", BFGoodrich "G-Force", Firestone "Firehawk" are not specific tires, they are a very broad/wide range of tires, some of which are probably great, some of which are likely not so great).
Advice like: "I've always gotten Goodyear Eagles, they're great tires" or "I had a set of Kumho Ecstas and they sucked" is pretty much meaningless because there are both good and bad tires that go by those names.
Wepeel (11-13-2013)
245/40/17 summer tire recommendations needed OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-25-2013 09:15 AM
Tire recommendations Shenks Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 09-24-2013 11:46 PM
Tire Recommendations Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 09-16-2013 11:06 PM
Inexpensive but Safe Tire Recommendations? Anthony Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 08-13-2013 11:18 PM
Need Tire recommendations please, non track use JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 01-03-2013 04:15 PM
