Old 11-12-2013, 08:32 AM   #1
FerraraZ
Drives: 13' FR-S Firestorm Red
Which OBD vendor did you select?
Wanted to bring about the discussion of OBD2 bluetooth sensors and what brands or online retailer you selected for this. I havent researched much but my plan is to drop an Android tablet into the dash of my FR-S and use the OBD2 Tuner program for all relevant car statistics.
The most important stat which I am trying to achieve is miles before empty. From what I'm reading, people have had great success with a wide range of devices that differ in price from 20-200.
I would love to see what other people purchased and how they are using their sensor. Are you leaving the sensor plugged in even when the vehicle is not on?
FerraraZ is offline   Reply With Quote
Old 11-12-2013, 12:11 PM   #2
I have a "Torque" program on my smart phone that gets a signal from the OBD2 port via an inexpensive bluetooth sender.
It works OK, however, I'm afraid to keep it plugged in all the time. Why? Because the sending unit has a little red light that stays ON even if the ignition is OFF.
Why does that bother me? Because the government may be spying on me .....
Old 11-12-2013, 01:04 PM   #3
FerraraZ
And see that was my issue too however if you check the link below, they claim that it is safe to leave plugged in but this is a $150 OBD sensor compared to the cheaper $20.
http://www.scantool.net/obdlink-mx.html
Old 11-12-2013, 01:26 PM   #4
jamesm
it depends what you want it for. if you just want to see parameters on a screen, particularly ones that don't change often like temps, then any old bt obd2 device will work (even the cheap ripoff elm327's from ebay).
if you plan to watch something that changes rapidly (afr, boost, etc) and gain useful information or log from it, then the chinese clones are all but useless. really, any elm327 is as the minimum reliable polling rate for even a legit elm327 is 300ms, and the knock-offs often can't do even half of that.
the best devices i've found for logging obd2 are the innovate ot-2 or tactrix cable, depending which software you plan to use. both are capable of speed more than adequate for logging. plx also makes a bt-compatible device that should provide useful data.
Old 11-12-2013, 02:31 PM   #5
FerraraZ
Well the most important stat I want immediately is miles until empty. I want to then use that info to push to a new in-dash system. I would also like to not have to disconnect the sensor everytime I turn the vehicle off. Are my desires unrealistic?
Old 11-12-2013, 04:09 PM   #6
jamesm
i leave my ot-2 plugged in (whenever the tactrix cable isn't in there). they say if you leave it a long time it could run your battery dead, but i haven't experienced anything close to that and i don't drive often at all.
the in-dash system you plan to use will dictate what type of interface you need to buy.
Old 11-12-2013, 04:23 PM   #7
Hagbard
Hagbard's Avatar
Have a PLX Kiwi Bluetooth one its not cheap but works well with alot of apps.
Hagbard is offline   Reply With Quote
Old 11-12-2013, 04:25 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I am pretty sure any BT OBD device will be able to poll more than enough for a DTE calculation.
Old 11-12-2013, 05:14 PM   #9
Maybe I'm just paranoid about the light remaining ON, howwever, I can't keep from driving my FR-S long enough to let it sit and test it. Just my luck, that $20 thing would fry my cars ECU .....
Old 11-12-2013, 05:23 PM   #10
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
1. open bt obd-2 device
2. locate led
3. remove led
no more light staying on when car is off draining battery
Danklvr is offline   Reply With Quote
The Following 3 Users Say Thank You to Danklvr For This Useful Post:
amram (04-07-2014), DC2R (07-02-2014), humfrz (11-12-2013)
Old 11-12-2013, 06:49 PM   #11
arghx7
Drives: car
If you actually want to take logs and do work with it, a PC-based (or maybe Mac, but basically not a tablet) solution might be easiest. For universal OBD II use, I prefer the OBDWiz software with one of the compatible plug-ins. http://www.obdsoftware.net/obdwiz.aspx . Elmscan 5 is cheap and works well.
If you are going to put a tablet in there and look at it all the time--well you've got glare issues, and battery life issues, and all of that stuff. You have to put it somewhere. I think once the novelty wears off you won't find it that useful.
If you just want distance to empty, use your phone.
Old 11-12-2013, 09:10 PM   #12
Hagbard
Hagbard's Avatar
Not just the light in some of them if the device its self is not smart the BlueTooth could still be running as well.
2. locate led
3. remove led
The Following User Says Thank You to Hagbard For This Useful Post:
amram (04-07-2014)
Old 04-07-2014, 07:21 AM   #13
amram
amram's Avatar
Drives: 2013 FR-S AT
Yes reading some of the reviews off amazon for the $20 cheap ones, some people have said that they were able to connect to wifi also after car was off and key out (overnight even, so not like 5 mins after). So it's more than just led on. The more expensive ones (plx kiwi Wifi 2 for eg) seem to have a sleep mode where it turns off after some inactivity. See -
"The Kiwi 2 Wifi incorporates a new advanced power saving circuit, designed to shut off power to essential functions of the unit allowing the Kiwi 2 Wifi to be permanently installed in your vehicle without draining your vehicle's battery. After 5 minutes of inactivity, the Kiwi 2 Wifi automatically enters a low power sleep mode. To turn the unit back on, a simple press of the soft switch wakes the device back up."
But the con is it seems you need to press a 'soft switch' to wake it up. At least the kiwi one. Others may have an auto wake on car start.
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 04-07-2014, 09:27 AM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
Anyone know where I can purchase the GoPoint BT1 or BT1A?
FS: Version Select TRD Front Lip Kit gvan1998 Exterior Parts (Aero, Lighting, Etc.) 13 06-16-2013 10:33 AM
FS: Version Select TRD Front lip painted gvan1998 Exterior Parts (Aero, Lighting, Etc.) 7 06-04-2013 10:56 AM
FS: Version Select TRD Front lip Painted gvan1998 Mid-Atlantic 2 06-02-2013 11:37 PM
FS: Version Select TRD Front lip painted gvan1998 NY / NJ / CT / PA 4 06-02-2013 11:32 PM
