Old 09-21-2013, 12:12 AM   #15
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i have the click sound when i release the brake pedal. I took it in to the dealer and they checked and saw nothing wrong.
chenshuo is offline   Reply With Quote
Old 09-22-2013, 11:35 AM   #16
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Maybe this is the sensor that let's the car know the pedal is engaged?
B-R-Z is offline   Reply With Quote
Old 09-22-2013, 03:21 PM   #17
Mikem53
Drives: FR-S 6MT
Originally Posted by uEih View Post
I have this too, it sounds like it's coming from the clutch pedal, it's sounds more harsher than a click though. Like a few clicks simultaneously. I was wondering if it was an issue that should be brought up since I'm going to bring it to the dealer soon, I also have crickets.. I don't know if they'll do anything about them though but sounds like I have bad belts.
I believe there is an assist spring assembly in the clutch linkage. I would
Look into that being the source of your noise.. The switch is right there at the top of the pedal.. Stick Your head down there and push the pedal in and listen for the spring noise.
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
uEih (09-22-2013)
Old 09-22-2013, 06:23 PM   #18
uEih
Drives: CBS Subaru BRZ Limited
I noticed that when I press on it while not moving it's fine. It's when I'm switching gears and moving that's why it's a bit odd.
uEih is offline   Reply With Quote
Old 09-29-2013, 01:40 PM   #19
jflogerzi
jflogerzi's Avatar
I have this same noise. Its off and on. With the windows down and the radio off I can hear it for sure. It seems like right as I let off the clutch and go to give the car power I hear this noise. Next time I am at the dealer, I will bring it to there attention.
Old 09-29-2013, 10:49 PM   #20
uEih
Keep us updated, I'm going to make a dealer stop soon and wanna talk to them about it but if I can't replicate it, it's pretty pointless. I also noticed that sometimes when I don't even clutch and just let go of the gas and press it again it makes the same exact noise. So if the noise I'm hearing is the same you guys are talking about it's probably more towards the gas pedal than the clutch.
Old 06-01-2014, 05:17 PM   #21
jay_
Drives: 2014 DGM Subaru BRZ limited 6MT
Any update on this? My brz is only couple months old and ive noticed when im starting from a stop, releasing yhr clutch with gas would make this zzzzzz noise. It is not consistent but usually happen when im starting on an incline going uphill. Anyone got any clue? Help a fellow brother out
jay_ is offline   Reply With Quote
Old 06-01-2014, 07:31 PM   #22
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Old thread... but the clicking is normal.
Old 06-01-2014, 09:46 PM   #23
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
No, depends on the type of clicking.
Check the thread
http://www.ft86club.com/forums/showthread.php?t=57383
If it sounds like that, it can be fixed. Some times it comes back for me, but it's the one bolt there that makes a noise. I just adjust it as I hear it come back
86-tundra is offline   Reply With Quote
Old 06-03-2014, 12:46 AM   #24
jay_
im not sure if its that popping sound. my sound only occur when my car is on
Old 06-03-2014, 03:53 AM   #25
Kostamojen
I have a similar sound. I figured out where it comes from, but I haven't fixed it yet. Its kind of a combo click/rattle when engaging/letting up the clutch pedal.
Anyway, where the clutch "piston" goes into the master cylinder, there is a thin metal O plate than sits around the pin and just inside the master cylinder. When engaging the pedal, it takes pressure off this place and it moves slightly in the space that it has and rattles. I'm going to try and get it fixed eventually, but its very off/on and I think some grease in there might quiet it up, something to keep it from shifting around so much.
Old 06-03-2014, 05:19 PM   #26
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I had this on another car - isolated the sound to be coming from my left knee. Yes kids, one day your body will crack and creek when you move your joints!
ashtray is offline   Reply With Quote
Old 06-03-2014, 08:24 PM   #27
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I tried the fix that @trevorovert posted and it muffled the sound a decent amount. It's still there though, just gonna live with it or loosen it up a bit.
unsurety is offline   Reply With Quote
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
noise when releasing clutch/shift resistance abutterman Issues | Warranty | Recalls / TSB 11 07-20-2013 09:23 AM
New Clutch Pedal Stopper -- Bang For The Buck Mod!! 86_ZN6 Interior Parts (Incl. Lighting) 1 04-17-2013 10:26 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
