Old 09-21-2013, 09:09 PM   #1
ZackZ
Drives: '13 Scion FR-S Black 6sp man
Help! Jumpy/Uneven Acceleration
Manual transmission. I notice that when I strongly accelerate in first gear, power is not 100 percent. It almost feels as though the clutch is slipping but the car only has 375 miles. Could this be traction control kicking in to prevent wheel spin. Should I take it to my dealer? Thanks.
ZackZ is offline   Reply With Quote
Old 09-21-2013, 09:19 PM   #2
Gaiseric
Gaiseric's Avatar
Drives: 2012 Scion TC
You might just be experiencing the Torque Dip, the clutch shouldn't be slipping and i doubt its your traction control.
Bolt ons and a tune will minimize your torque dip and better tires will give you better traction, so those could be some future options for you.
Gaiseric is offline   Reply With Quote
The Following User Says Thank You to Gaiseric For This Useful Post:
ZackZ (09-21-2013)
Old 09-21-2013, 09:22 PM   #3
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
try rolling onto the throttle
andrew5826 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew5826 For This Useful Post:
mikeTee (09-21-2013), ZackZ (09-21-2013)
Old 09-21-2013, 09:22 PM   #4
kodyo
Drives: Scion FR-S
Without driving it myself, my guess would be synchros and gear ratio difference between 1st and other gears making it seem off.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
ZackZ (09-21-2013)
Old 09-21-2013, 10:38 PM   #5
fstlane
fstlane's Avatar
Drives: BRZ Limited
I bet this is the case also. I almost took mine to the dealer after the 1st day because I swore it felt like it was running on 3 cylinders. It just took some getting used to the torque dip and learning to drive above and below it. For me the car likes to be either short shifted for normal acceleration or shifted near the top of the rpm range for spirited driving. I also noticed my car felt stronger once I got a couple thousand miles on it. I recently got an Openflash tuner which helped the torque dip a LOT. Enjoy your new car!
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
ZackZ (09-22-2013)
Old 09-21-2013, 10:42 PM   #6
roddy
roddy's Avatar
Drives: '13 Ultramarine
Next time this happens, keep an eye out for the yellow light flashing in the gauge cluster. I know in my car if I nail it from a roll in 1st gear, It breaks traction easily with the TCS turned off on sooth pavement. My money's on TCS stepping in.
The Following User Says Thank You to roddy For This Useful Post:
ZackZ (09-22-2013)
Old 09-21-2013, 11:07 PM   #7
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
This. Once I did this, it helped a lot with the jumpyness.
mikeTee is offline   Reply With Quote
Old 09-21-2013, 11:42 PM   #8
SLEEPER WRX
Wait . . . 375 miles and your "accelerating strongly"?
Maybe think about taking it easy and doing a "break in"?!?!?
SLEEPER WRX is offline   Reply With Quote
Old 09-22-2013, 12:03 AM   #9
Good point about break in.
I would suggest you take it sort of easy for a few more hundreds of miles. Your car may settle down after it gets limbered up....
ZackZ (09-22-2013)
Old 09-22-2013, 01:18 AM   #10
ZackZ
I keep it below 4,000 rpm only once in a while i step on it
Old 09-22-2013, 01:20 AM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
o lawd jesus, not this break in shit again
As for OP it is probably just the torque dip
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post:
Opposed (09-22-2013), Roadliner (09-22-2013), ZackZ (09-22-2013)
Old 09-22-2013, 01:22 AM   #12
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
please shutup about breakins lol. No one needs another thread
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
Old 09-22-2013, 12:38 PM   #13
jflogerzi
jflogerzi's Avatar
+1
Old 09-22-2013, 12:42 PM   #14
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
the highway on-ramp that I take 99% of the time has two bumps/crack right before merging... the car is at the top of 2nd right around this time, high rpm... right around 60 mph. Before, the car's drive-train would "lash", I would hop a bit inside the car and the rear-end would hop after the lash made it's way down the to the differential. Power being embarrassingly lost and the car would disconnect from myself, the driver.
After installing the Whiteline Transmission Bushing Insert, that had all but disappeared.
The car feels VERY firm and planted now under load going over those very bumps.
Just FYI, from the factory, the car has .5" of play on the transmission mount, you are more than likely feeling this "slack" that I felt.
hamzam is offline   Reply With Quote
The Following User Says Thank You to hamzam For This Useful Post:
ZackZ (10-01-2013)
acceleration thump mid_life_crisis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2013 09:19 PM
uneven engine vibration at idle whtchocla7e Issues | Warranty | Recalls / TSB 17 08-07-2013 09:21 PM
Acceleration Lag - Intermittent donnyk CANADA 6 07-17-2013 11:53 PM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 04:25 PM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 06:56 PM
