Old 09-19-2013, 01:46 AM   #1
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Unichip + Fluxx2 and an OBDII "Y" Splitter
@Unichip Jack
Before I purchase an OBDII "Y" splitter, I was wondering if you knew if it is possible to run the Fluxx2 and an OBDII logger simultaneously via "Y" splitter. If so, do you have a recommendation on the splitter? Thanks in advanced.
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 09-19-2013, 02:28 PM   #2
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Thanks for the post.
We've never tried it, but I suspect you'll find issues because the devices don't just "listen," but they actively send data request on the data bus for the information they want.
When one asks a question, the other isn't looking for the same information at the same time and it doesn't know what happened to the data it wants, so it asks again and both will probably shut down until things return to normal.
Cheers
Unichip Jack is offline   Reply With Quote
The Following User Says Thank You to Unichip Jack For This Useful Post:
ReThink (09-19-2013)
Old 10-11-2013, 01:21 PM   #3
ReThink
ReThink's Avatar
Y Cable and Flux works
I just installed the "Y" cable and the unichip and the BT1 works perfectly so far. I am able to log the same parameters that the Flux2 is monitoring as well.
Sc10n FRS #0664
Old 10-11-2013, 08:08 PM   #4
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
which y cable did you get and what is BT1
garfull is offline   Reply With Quote
Old 10-12-2013, 03:38 PM   #5
ReThink
ReThink's Avatar
@garfull
It was some random splitter I found on eBay. Something to note. Get a cable with the male end at a 90deg angle. I had to relocate my OBDII port because of this oversight.
The BT1 is what I use to interface my iPhone or computer to the car for logging signals via OBDII. Its from GoPoint Tech.
Sc10n FRS #0664
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
