Old 07-30-2013, 01:26 AM   #1
Yruyur
Yruyur's Avatar
Warning Led Switchback Users
A few members locally have switchbacks installed and think we discovered an issue with these Chinese switchbacks.
These switchbacks required slight enlargement of the hole because the led array is so large. I know some dont require this modification as they are a smaller diameter.
A few of us thought we had a fogging issue at first. We thought water was getting inside seal area that was modified.
We pulled one set apart this weekend to black out the chrome and dry out what we thought was water.
Well the fog would not come off. In fact it was solid. We believe there is an adhesive they use in the bulb or to attach the led array that is getting heated and turning into a glue fume thats sticking to everything in the housing.
Polish would not remove it, alcohol didn't touch it, baking soda didn't do anything either. A fingernail would scratch it but could not get it even. We ended up using a small buffing wheel on a dremel to get most of it off. It is not optically perfect but better than looking completely fogged over.
Another symptom that indicated the adhesive is a booger of a glue in the bottom of the housing was found in two lights.
I had the same brand and for longer but only had what appeared to be small drops of this inside the lights. They may have changed the manufacturing process at some point but no way to be sure.
Just wanted to give folks a heads up.
Thanks to @jeffsides for diagnosing the issue and @Sivtec for letting us look at his lights
Sent from a Motorola DynaTAC 8000X
The Following 7 Users Say Thank You to Yruyur For This Useful Post:
Jar (07-30-2013), jeffsides (07-30-2013), PantsDants (08-04-2013), redsuns03 (07-30-2013), Shim (07-30-2013), Sivtec (07-30-2013), Sportsguy83 (07-31-2013)
Old 07-30-2013, 01:51 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
WHAT brand should we be aware of?.....
Old 07-30-2013, 01:58 AM   #3
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
I had the same issue with my first set of switchbacks. One of them got so hot, the LEDs literally started to melt right off the its board. I switched them out for different ones which I have had no issues thus far. But because of the first set, just one of my lamps looks exactly like that Def seems like some kind of smoke damage to the lens. Its just seems like a lot of work to take apart everything to clear it up
ThaBigUnit is offline   Reply With Quote
Old 07-30-2013, 02:00 AM   #4
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
The ones the messed my car up originally were from Concept-3-LED, but when I told him the issue I had. He gave me a completely different version/brand that have been awesome and do not get hot at all
The Following 2 Users Say Thank You to ThaBigUnit For This Useful Post:
enjoi23 (10-13-2013), OICU812 (07-30-2013)
Old 07-30-2013, 09:47 AM   #5
Yruyur
Yruyur's Avatar
Actually you can remove the light without bumper removal. Just remove the bezel by popping it out and reach inside with a wrench to remove the two nuts.
Baking them at 225 for 15 and they separate easily.
Old 07-30-2013, 09:58 AM   #6
Asphalt~86
Drives: Asphalt AT
Crazy, I've had these since release, have the larger switchbacks as well and have zero issue. Also never had to enlarge the hole to get the fitment right...
Asphalt~86 is offline   Reply With Quote
The Following User Says Thank You to Asphalt~86 For This Useful Post:
Yruyur (07-30-2013)
Old 07-30-2013, 11:47 AM   #7
turbos86
Drives: 2014 Zenki 37J
Are these the problematic ones?
turbos86 is offline   Reply With Quote
Old 07-30-2013, 12:04 PM   #8
Yruyur
Yruyur's Avatar
They look similar packaging is a little different. You could hook them up to a 12 volt power supply and set them in a jar to see if they off gas. Once they finish you would probably be safe installing them.
The Following User Says Thank You to Yruyur For This Useful Post:
turbos86 (07-30-2013)
Old 07-30-2013, 12:11 PM   #9
Diode Dynamics
Diode Dynamics's Avatar
Our switchbacks will not cause any heat issues like this and don't require you to make any modifications to your housings. We have them in our FRS and they function perfectly.
The 7443 bulb must be less than 22mm in diameter. Many Chinese sellers don't realize this, which is why your bulbs were too big.
This is why you shouldn't buy cheap bulbs. They are put together or sealed with bad epoxy, which melts and emits a gummy residue after being heated up. I've seen it with other fog light LED applications as well when eBay bulbs were used.
If you ever have questions about switchbacks, you can always shoot me a PM on here.
Thanks,
-Nick C.
John C.
Diode Dynamics
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
texasbound972 (07-31-2013), Yruyur (07-30-2013)
Old 07-30-2013, 12:54 PM   #10
nalc
Drives: 13 BRZ Limited 6MT GBS
It might be silicone sealant, that will release fumes into the housing even after it has dried, people now avoid using it for headlight retros for that reason.
nalc is offline   Reply With Quote
Old 07-30-2013, 02:52 PM   #11
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
That type of "fogging" is from super glue........only way I know to get that off is by polishing the lens with rubbing compound.
IceFyre13th is offline   Reply With Quote
Old 07-30-2013, 03:15 PM   #12
camelflage
Drives: pinto power
i got mine from @JWMotoring and the LEDs were about half that size. will keep an eye on it and post if mine start having issues.
camelflage is offline   Reply With Quote
The Following User Says Thank You to camelflage For This Useful Post:
JWMotoring (07-30-2013)
Old 07-30-2013, 06:45 PM   #13
Yruyur
Yruyur's Avatar
I have not seen any issues with my v3 triton switchbacks. Even though they are 600 lumen I don't think they used any type glue that is off gassing.
Link in my signature
Old 07-30-2013, 07:18 PM   #14
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Thanks,
-Nick C.
Got my LED's from Diode. No issues, been about 3k miles too.
The Following User Says Thank You to Khazzy For This Useful Post:
Diode Dynamics (07-30-2013)
E85 USERS!!! Please read, interesting stuff! Sportsguy83 Engine, Exhaust, Transmission 118 05-28-2013 08:37 PM
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 06:52 AM
Marginally good use for BeSpoke users! Mandy Electronics | Audio | NAV | Infotainment 12 02-15-2013 09:07 AM
E-85 users thread Crossover Auto Engine, Exhaust, Transmission 41 11-16-2012 07:21 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 09:34 PM
