Old 07-07-2013, 11:49 AM   #1
Benn0r
Drives: 2013 Toyota 86 GTS
need an oil catch can for vortech\innovate superchargers?
Hi guys,
I am a new innovate supercharger owner, will be getting it installed \ dyno'd in the next few days. Can any of you let me know whether or not you have needed to install an oil catch can system on your innovate\vortech supercharger systems?
Cheers!
Benn0r is offline   Reply With Quote
Old 07-07-2013, 01:49 PM   #2
Dezoris
Dezoris's Avatar
http://www.ft86club.com/forums/showp...3&postcount=75
Read that and decide.
My opinion is yes, mostly for efficiency sake. For the Vortech its a must and the breather line runs right into the supercharger path and then down to the intercooler.
Old 07-07-2013, 01:50 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Benn0r View Post
Hi guys,
Cheers!
Do you NEED one? No. The car will run just fine without.
SHOULD you get one? Yes. By reducing or eliminating the oil that enters the intake, you'll get less knock and can run better timing.
The thing is, horizontally-opposed (boxer) engines tend to have pretty dirty PCV systems; especially if you do AutoX or track-days. The oil won't leave the heads as readily under higher G turns which means it can get splashed into the PCV system. That oil will end up back in your intake and get burned off. And it doesn't take much engine knowledge to figure out what happens when an engine set up to burn clean fuel/air mixtures gets dirty oil sprayed into it.
With forced induction the issue can become worse as not only are you seeing higher speeds and potentially higher cornering forces, but you're also going to get higher crankcrase pressures which mean more volume through the PCV system.
TL;DR: An AOS isn't necessary, but it's a REALLY good idea.
The Following User Says Thank You to Draco-REX For This Useful Post:
roddy (07-07-2013)
Old 07-07-2013, 01:56 PM   #4
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
get one
btw im selling my crawford one
Old 07-07-2013, 03:12 PM   #5
Pete
Pete's Avatar
Drives: 22 BRZ
I got one for my car and it catches about an ounce of oil/fuel a week. I would say yes you should get one.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-07-2013, 03:52 PM   #6
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
What catch can would you recommend?
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 07-07-2013, 04:35 PM   #7
roddy
roddy's Avatar
Drives: '13 Ultramarine
Well said.
Old 01-17-2014, 01:17 AM   #8
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
@Benn0r did you end buying a catch can? I'm wondering if the Innovate SC clears the Crawford AOS.
Perihelion is offline   Reply With Quote
Old 01-17-2014, 01:50 AM   #9
whataboutbob
AutoX-10/10ths every run
I had one and no it doesn't. Radium Engineering is going to be selling a twin-specific one in the next couple of weeks.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
JoeBoxer (01-17-2014), johnb831 (01-17-2014)
*Vortech Superchargers - Plenty in stock at RallySportDirect.com!!* RallySport Direct Forced Induction 9 07-30-2013 09:08 PM
HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO D2BD Motorwerks Forced Induction 7 07-01-2013 01:45 PM
Vortech Superchargers Garage Sale THIS WEEKEND! Brian@Vortech Southern California 2 05-10-2013 08:51 AM
WHERE THE F*** ARE SUPERCHARGERS Billy2224 AUSTRALIA 11 10-04-2012 11:41 AM
Boxer Engines and Superchargers brillo Engine, Exhaust, Transmission 2 01-06-2012 05:49 AM
