Overthinking it
Drives: BRZ in CS
RTR/CS people - Front Sway bar FRS vs. BRZ
With respect to a modifying the front sway bar, is there any significant difference in front swaybar selection for a BRZ compared to a FRS.
The FRS has 135/211 #/in springs and is more tail happy than the BRZ. A big front bar works well here. For a 22mm Strano bar, I get a 72.5% TLLTD from my magical spreadsheet. The BRZ has 153/195 #/in springs and is a little more pushy than the FRS. In concept, putting on the same size bar (as you would on the FRS) would make the BRZ understeer more. For a Strano bar, I get a 73.1% TLLTD (a tad more push). To get the same handling characteristics, a smaller bar than the FRS would make more sense - say a 21mm. The tradeoff would be more body roll with the smaller bar. Has anyone taken this into account? Is there any appreciable difference between an FRS and a BRZ with the same sway bar? Or am I trying to apply too much logic to stock class? Put on a big ass bar and race it. |
#2 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Have you done much autocrossing with the car yet in stock trim?
I would not consider the car pushy enough to change direction... I'm pretty sure the only bar readily available that is a smaller rate than the Strano bar is the OE bar anyway.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | Kido1986 (05-30-2013) |
#3 | |
I was going to try each at different events but got lazy and have just left the Strano bar installed so far, but will be using the WL next event. The WL has more adjustability obviously with two holes (can use different holes on each side) as well as adjustable endlinks. Perrin also now makes a 19/20mm adjustable solid bar. |
| The Following User Says Thank You to xwd For This Useful Post: | mla163 (05-30-2013) |
#4 | |
The BRZ had much more oversteer. You might ask TRev, or John Ryan, the car owner. My FRS wasn't pushy, but there wasn't much in the way of rotation. And still isn't. |
| The Following User Says Thank You to des For This Useful Post: | mla163 (05-30-2013) |
#5 | |
Drives: ND2, formerly BRZ (MT/CBS)
I felt all last year that the 20mm Cusco was not quite enough, even on the 'pushier' BRZ. I kept it in the garage for fear the Strano bar would be too stiff, but I have no plans on changing back as the Strano bar feels pretty good to me and Sam was able to turn some pretty good times with the setup that is on the car now. (link) The final answer is probably a bit driver dependent, ymmv, etc. |
#6 | |
Drives: 2006 Honda s2000
| The Following 3 Users Say Thank You to ViperASR For This Useful Post: |
#7 |
Overthinking it
Drives: BRZ in CS
| The Following 2 Users Say Thank You to mla163 For This Useful Post: | supramkivtt2jz (05-31-2013), whataboutbob (05-31-2013) |
#8 |
Detroit Region, MI
For anyone reading this please also remember that bar diameter is in no way a direct correlation to the bar rate. Unless you know the wall thickness of a hollow bar, it's material, how it was treated, and the bar-to-wheel motion ratio, you really cant guess at the true influence on wheel rate too accurately.
I was trying to gather all this info before, but essentially gave up because claims and numbers didn't match... need real data, too much coming from the internetz.
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | CSG Mike (05-31-2013) |
#9 |
Apostle
Drives: JesusMobile
#10 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Put the magical spreadsheet down, pick up the phone, call Stranoparts, order their 22mm bar, install it, drive the car, have fun. Made a significant difference on my BRZ for autocrossing, subtle improvement for driving on the street. Love it.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| Rear/Front Sway Bars on the BRZ | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-24-2013 05:54 PM |
| 22mm Tubular Front Sway Bar $130.00 | AX FRS | Brakes, Suspension, Chassis | 2 | 03-04-2013 06:14 PM |
| Front Sway Bar endlinks | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-30-2012 04:14 PM |
| Hollow front sway bar: Tanabe? | simpleisbest | Tracking / Autocross / HPDE / Drifting | 33 | 09-25-2012 09:59 PM |
