Old 03-16-2013, 01:58 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
visconti tune . launch control. help
Hey guys. just flashed this morning. can't seem to get launch control going except once today and not even sure how i did it haha. i tried all maps except 1 since that's stock. so from my understanding. first gear. at zero. clutch in. then you...floor it right?. any input would be great.maybe the clutch isn't all the way to the floor?
ft86me is offline   Reply With Quote
Old 03-16-2013, 02:02 PM   #2
congiiee
Drives: WRB Subaru BRZ
Make sure you're in map 2,3 or 4. Check if anything is in the way of the gas pedal. If not then change maps, gear one, slam the gas pedal and it should work.
congiiee is offline   Reply With Quote
The Following User Says Thank You to congiiee For This Useful Post:
ft86me (03-16-2013)
Old 03-16-2013, 02:33 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
with clutch in right?
Old 03-16-2013, 03:12 PM   #4
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
After you stop, pull it out of gear then back in 1st, then floor it very quickly.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 03-16-2013, 05:03 PM   #5
congiiee
yes clutch in lol. tell me if it works. it felt very uncomfortable slamming the gas because if you don't do it fast enough it will bounce the rev limiter. just practice
Old 03-16-2013, 07:06 PM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
haha. it worked. map 2 and up. clutch ALL the way in. hit the gas to the floor and it engages. from there you get go up or down with the cruise control in terms of the rpm. had a little fun with that on map 4. dropped the clutch and got sideways hahaha. so fun
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Ecutek visconti tune ft86me Engine, Exhaust, Transmission 24 03-14-2013 10:35 AM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 05:27 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 04:22 PM
