Old 11-25-2012, 11:34 PM   #1
sirhc
sirhc's Avatar
Drives: fr-s
DIY JWMotoring LED turn signals
This is a very simple thing to do took maybe 10 mins and that was with taking pictures. This will cover the basic LED installation and the Swithback LED's
Tools needed. your keys, Philips head, and small flathead screwdriver, zipties
1 move seat all the way back and look under your dash you are going to find relay circled in red and remove the plug circled in blue, you will attach this to the supplied relay, ( ziptied the new relay under the dash)
2.get in your car, put your key in and turn to accessory. you do not need to actually park your car
3.. take your steering wheel and turn your wheels either all the way left or right depending on which side you want to start on.Turn off car remove keys
4.. get out and remove the three screws that hold the bottom of the wheel liner in. you may need to use your small flathead screwdriver behind the head of the screw
5. then you can pry the fender liner back and get to the bulb assy.
6. put your hand in the opening and grab the light assy and turn left and pull it out from the liner
7. put in the bulb you got to replace the your stock ones, before you put it back in your might turn on your park lights to be sure it lights up you can put these in backward and they wont work.
8. put the bulb assy back in turn to the right to lock it back in, put the screws back and repeat steps 2-8 for the other side, and your done
Stock orange
LED orange
LED white
and a video of the swithback working both turn signal and hazard
[ame="http://www.youtube.com/watch?v=RBG_7EtSWyY&feature=g-crec-u"]JWMotoring 2013 FR-S switchback Led turn signals - YouTube[/ame]
yes I changed my rims with in this also.
Thanks
Chris
sirhc is offline   Reply With Quote
The Following 2 Users Say Thank You to sirhc For This Useful Post:
mikeg7827 (12-05-2012), scottmcphee (03-30-2013)
Old 11-26-2012, 01:40 AM   #2
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
so this turns the parkers/DRLS into indicators?
Surok is offline   Reply With Quote
Old 11-26-2012, 06:59 AM   #3
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Thanks again for the write up.
These products will be offered from us in the next month for everyone that is interested.
JWMotoring is offline   Reply With Quote
Old 11-26-2012, 01:50 PM   #4
sirhc
sirhc's Avatar
Drives: fr-s
No this is for the park/turn signals only the DRLS are something different
Old 11-26-2012, 02:08 PM   #5
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
For noobs like myself, an important first step before installing the new relay is to disconnect the battery. Honestly, I learned that the hard way. Blew a fuse and I had no idea what the hell was wrong with my car.
There's a chance your buse won't blow if you don't disconnect the battery, but better to be safe than sorry. Especially since disconnecting your battery takes like a minute or two only.
i_4got is offline   Reply With Quote
The Following 2 Users Say Thank You to i_4got For This Useful Post:
mikeg7827 (12-05-2012), Scionshaun (05-24-2013)
Old 11-27-2012, 10:41 PM   #6
Joesuede
Drives: Argento FR-S
Send a message via AIM to Joesuede
Is the second step missing? You are missing #2, n i was just curious about what the new relay looks like
Joesuede is offline   Reply With Quote
Old 11-28-2012, 07:04 PM   #7
sirhc
sirhc's Avatar
Drives: fr-s
Sorry I will change that. And the new relay looks identical to the oem one its just says LED relay on it
Old 11-28-2012, 08:00 PM   #8
wparsons
wparsons's Avatar
Does the relay alone disable the usual DRL's, or was that another step?
flickr
Old 11-28-2012, 08:39 PM   #9
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Last weekend I installed a 6000k HID kit for my FRS and these LED turn signals will be a great addition. I was wondering if the LED white matches better with the 6000k or 5000k.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 11-28-2012, 08:43 PM   #10
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
so tell me why the indicators would stay on? and not flash
so you have park lights.. ?
so all your indicators just stay on?
Old 11-28-2012, 09:02 PM   #11
Draco_PR23
Fiebru
Draco_PR23's Avatar
Someone correct me if Im wrong but by default, the indicators stay on with the lights on and only flash when you use the turn signal switch.
Current Cars:
Old 11-29-2012, 09:37 AM   #12
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
6000k matches these better. 5000k would be close and I doubt you could tell the difference.
The Following User Says Thank You to JWMotoring For This Useful Post:
Draco_PR23 (11-29-2012)
Old 11-29-2012, 09:38 AM   #13
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
I believe there is a difference across the different models on how these lights will work. I'll search for it when I get a free moment.
Someone that has the info help me out.
Old 11-29-2012, 10:36 AM   #14
wparsons
wparsons's Avatar
With the lights fully off (DRL on only) these lights are off and the high beam bulbs are at lower power for DRL's.
With parking lights on these lights come on, in addition to the DRL's.
Lights fully on the DRL's are off, these bulbs are on and the low beam bulbs are on.
It would be nice to have these bulbs on for the DRL instead of the high beam bulbs, but I'm not sure how much wiring work that would take.
flickr
Are Switchback Turn Signals Legal? i_4got CANADA 7 11-03-2012 05:47 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 02:03 AM
