Drives: FR-S MT
Anyone having throttle issues?
My FR-S after 6,000 miles started losing power at times. Particularly at low revs, I'll be driving along and the engine starts to lose power a little, forcing me to press harder on the accelerator to compensate. Also, when I press the gas, when the car is at idle speed 650 rpm, the engine shivers a bit before picking up. I don't know it the two issues are related. I can rule out bad gas, since I have been using Shell 93. It is a stock motor.
#2 |
Sounds like the cel issue cropping up
Sent from my SCH-I535 using Tapatalk 2 |
#3 |
Drives: Firestorm Fr-S
Mine is starting to have the same sort of issue, only 800 miles though.
#4 |
Drives: FR-S MT
Can you describe what you are experiencing?
#5 |
Drives: White WRX Hatchback, Toyota Pickup
Sounds similar to this: http://www.ft86club.com/forums/showthread.php?t=16997
I've experienced this too, intermittently, only when accelerating from a stop (coming off of idle). RPM's dip slightly, feels rough. Not very noticeable, but it does happen from time to time. 1200 miles on my car. My 1968 Datsun 2000 would so this too - didn't expect it from my brand new BRZ.
2013 Subaru BRZ, SSM Limited
vin: 6007xx build: 3/2012 |
#6 |
Drives: GT Blue Hachi Roku, Pile of Hondas
Ours does it too sometimes - almost like a very sticky throttle cable might feel, if it had one.
Also, S2000 do it worse and it's due to heat soak due to their poor intake design. I think it's jammy cams in his case, but it might easily be something else. |
#7 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#8 | |
Drives: FR-S MT
#9 | |
Drives: 2013 BRZ Limited 6MT
Edit: you open up your intake and look for any obstructions @ filter? Reason I ask is I had a rubber glove left in mine from factory. Leaf or anything it sucked in could cause probs too and easy thing to check off of your list. Mouse nest thread was the best so far. Ugh. |
#10 |
The cure seems to be to take it out for a good ragging down a back road.
It's sweet as a nut again now. I wonder if it's the DI making it a bit cokey in heavy traffic? |
#11 |
Drives: FR-S MT
No Mods on the car. Checked the filter - it is clear. Ran the car at high RPM's too. Did not change the problem.
"Cokey" is a new one to me. |
#12 |
Figured that wouldn't be it, but also figured there wouldn't be a rubber glove in the intake on mine, ha. I will say that I got a bad tank of gas from a reputable place that I get gas from often and had some issues. Knock correction was spitting out high numbers (over -4) and had bogging. Was worst going from off throttle to 1/4 or 1/2 throttle suddenly at lower rpms. Feathering the throttle and full throttle wasnt as bad and disappeared over 3k rpms. Wouldn't automatically check that off of your list because it's shell gas. All fixed with a new tank. Good luck!
#13 | |
Drives: FR-S MT
#14 |
Drives: t
my throttle is very laggy.. not sure if it was related to my cel/sl problem but it was like this from day one.. I had a cel come up pretty quick, under 300 miles.
| Dirty throttle body | AVOturboworld | Engine, Exhaust, Transmission | 11 | 05-11-2016 10:58 AM |
| Cusco 'Large Throttle' | ultra | Engine, Exhaust, Transmission | 3 | 09-05-2012 02:47 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| Throttle Controllers | harajukukei | Engine, Exhaust, Transmission | 31 | 07-28-2012 12:40 AM |
