Old 05-13-2022, 12:48 PM   #1
DJjoey0812
Drives: 2013 Scion Fr-s
FRS Rocker arm issues? Or rod knock?
This sound seems to be coming from cylinder 3, checked with a mechanics stethoscope to find the source. Anyone have a idea?
DJjoey0812 is offline   Reply With Quote
Old 05-13-2022, 01:01 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well, there are two modes of rocker arm failure that are known. It either spits it out in which case you will probably have a CEL for engine missfire along with other possible issues. Or the axle can slide out. I have never seen the axle issue and don't know what the exact symptoms are. I can't imagine the rocker staying in place for long if that is the case. Doesn't sound like rod knock.
Is this an MT or AT car? Have you stuck a stethoscope to the bell housing?
Old 05-13-2022, 02:33 PM   #3
DJjoey0812
So far it's been doing this for a little while, it didn't seem like rod knock to me and I know there are rocker arm issues, where they make stoppers for them. So far I haven't checked the bell housing, it is a AT for the time being till I do a swap
Old 05-13-2022, 02:38 PM   #4
AT vacuum pump. The noise is bang on. It is right back there by cylinder 3.
NoHaveMSG (05-13-2022)
Old 05-13-2022, 02:39 PM   #5
DJjoey0812
Cool I was worried because I just got the engine fully rebuilt brand new fully, I'll take some time later when I'm free and look into the vacuum pump. With the vacuum pump are there any symptoms with shifting at all?
Sent from my SM-G998U using Tapatalk
Old 05-13-2022, 02:41 PM   #6
Check this out
https://www.ft86club.com/forums/show....php?p=2786240
Old 05-13-2022, 02:48 PM   #7
DJjoey0812
I'm guessing it's this spot right here, secondary vacuum pump behind the 3rd cylinderName:  Screenshot_20220513-134745_Chrome.jpg
Old 05-13-2022, 03:40 PM   #8
I'm guessing it's this spot right here, secondary vacuum pump behind the 3rd cylinderAttachment 211895
Yep
DJjoey0812 (05-13-2022)
engine knock, issues, noise., rocker arm
IAM and Knock Issues: OFT Stage 2+/ Stage 2 + E85 DunkThemMuffins Software Tuning 1 12-11-2021 01:54 AM
Knock Knock? Expired Warranty Frivo Issues | Warranty | Recalls / TSB 20 08-17-2020 09:04 PM
Rocker arm ticking? Xman17 Issues | Warranty | Recalls / TSB 15 10-22-2019 02:56 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
