Drives: stock 15 FRS
socal smog legal exhaust
does anyone know which exhaust systems are smog legal in socal. I'm looking for something that adds some performance and has a nice sound to it. price isn't an issue but would rather something on the affordable side. Thanks!
#2 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
All exhausts are smog legal. its only the front pipe and the header that you cant change if you want to stay smog legal
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#3 |
Thanks!
#4 | |
About the only way to significantly increase power by modifying the exhaust, is to replace the header with one that doesn't have a cat. Therein lies the problem with staying smog legal in CA. Now, you can change the cat back or axle back portions of the exhaust system and get some cool sounds, but no significant power gains. The "simplest" way get some sounds and a small increase in power is go with a cat or axle back system, a freer flowing air filter and a tune (optional). humfrz |
#5 |
Drives: 2017 BRZ
Due to the recent increase in ticketing of modified cars in Socal, it might be better to avoid the headache of being sent to the state referee. Cat-back FTW
#6 |
+1. Also, be mindful that some exhaust systems are loud and they'll ticket you for excessive noise. CHP can also ding you with Ref too if they're in a bad mood as well
#7 |
All catback exhausts are *smog* legal, but may not be *sound level* legal.
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (06-27-2018) |
#8 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Just get the loudest catback
#9 |
Just gut the cat so you have the appearance of legal. 90% the power gain 0% the cost.
#10 |
#12 |
Human
Drives: 2015 BRZ Black
The only suggestion i have is try to find a high flow catted header that you can fit the stock heat shield onto with little to no modification.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#13 | |
Drives: Stockish 2018 Toyota 86
And even if you fail the smog test, there aren't any consequences. https://www.bar.ca.gov/Consumer/Road...n_Program.html |
| The Following User Says Thank You to Paul86Ski For This Useful Post: | BRZyJ (06-27-2018) |
#14 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Thaeyo (06-27-2018) |
| WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal | WORKS | Forced Induction | 415 | 10-16-2021 05:55 PM |
| Borrow/rent stock BRZ intake assembly for Socal smog | nickzue | Southern California | 8 | 09-26-2017 08:21 PM |
| WORKS Stage 2 Turbo Kit - Official Released! - Now CARB Compliant/SMOG Legal | WORKS | Forced Induction | 89 | 01-13-2017 04:41 PM |
| CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! | WORKS | Forced Induction | 47 | 01-13-2017 04:40 PM |
| WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal | WORKS | Forced Induction | 230 | 08-11-2016 06:01 PM |
