Drives: DGM 15' BRZ Limited
What's the suggest RPM threshold yo shouldn't exceed after first starting your car?
I turn my car on, wait a few seconds and then drive off. I try not to exceed 3k rpm in the first few minutes. Wondering if what I'm doing is ok or if I should change anything up.
#2 |
The Gunshine State
Drives: '14 BRZ Limited
From a cold start, I let the RPMs drop off to the normal idle before I move (usually only takes 30 seconds). From there, I keep it under 4k RPMs until it reaches normal operating temp.
What you're doing is fine.
![]() Current DD: M235i |
| The Following User Says Thank You to 8RZ For This Useful Post: | humfrz (10-12-2017) |
#3 |
The owner manual simply says "Do not race the engine on start up". No definition as to what "race" entails but since the break in max is 4,000 I would guess that exceeding 4,000 is what they mean.
#4 |
Drives: '13 FRS - STX
There was a brilliant detailed post a few years back from some dude in Norway I think who studied this kind of stuff at his job or something, someone dig that up that isn't me this morning, I haven't finished my coffee yet.
| The Following User Says Thank You to strat61caster For This Useful Post: | chaoskaze (10-13-2017) |
#5 |
#6 |
Just the tip
Drives: 2017 DGM BRZ
Same here. I let the cold start idle rpms drop before I leave, keep it under 3k for the first 5 or so minutes and under 4k until its warmed up... usually about the time I get to the freeway on ramp for a nice pull to get me up to speed
| The Following User Says Thank You to wolffbite For This Useful Post: | Somerandom18 (10-13-2017) |
#7 |
Drives: 2013 Scion FR-S Asphalt [Gray]
#8 |
That reminds me of a back-in-the-day story ....... yep, it's a slow day here in Puyallup.
I had just moved from California to Westport, CT. I was on the Merritt Parkway for the first time, screaming down the parkway in my MGB when the exit came up. Now, I was accustomed to the wide sweeping off/on ramps of California. So, when I exited onto the off ramp, I discovered that the surface was bricks and a much tighter turn than I was anticipating. Having a sports car ...... I thought ....... no problem ....... right ......?? While sliding around the tight turn, taking most of the "off ramp" ....... I discovered (as another car was coming at me) that the off ramps were also the on ramps ....... ![]() THE END humfrz |
| The Following 7 Users Say Thank You to humfrz For This Useful Post: | chaoskaze (10-13-2017), Spuds (10-12-2017), StraightOuttaCanadaEh (10-12-2017), strat61caster (10-13-2017), Tcoat (10-12-2017), TorontoNat (10-12-2017), wrh3 (10-12-2017) |
#9 | |
#10 |
#11 |
The Dictater
Drives: '13 Red Scion FRS
I watch my oil temperature which lags a bit behind the water temp. Usually oil temps are at 170-180 when coolant is up to temperature. That's about when I get to an on-ramp 5-10 minutes in. Until then, I try to keep it under 3.5krpm. Still a bit early at the on-ramp, but I can't resist either.
#12 |
#13 |
Noob
Drives: FR-S Mammogram
There's a small period, upon first starting a "cold" car, where the RPMs will stay slightly raised and then drop to normal idle. This is to warm the catalytic converter and is not necessary to wait for in order to drive the vehicle. Some people wait as peace of mind.
#14 |
Drives: '13 Whiteout
| The Following User Says Thank You to TommyW For This Useful Post: | TorontoNat (10-12-2017) |
| Why You Shouldn't Run Your Car Low On Gas | Extreme Dimensions | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 38 | 06-23-2017 07:47 PM |
| Steering wheel resistance while threshold braking | Pat | Tracking / Autocross / HPDE / Drifting | 28 | 01-25-2017 08:50 PM |
| Maybe I just shouldn't own this car | execoll | BRZ First-Gen (2012+) — General Topics | 26 | 12-06-2013 06:08 PM |
| Turbo Kits: Rational boost threshold yet? | Ryephile | Forced Induction | 88 | 01-22-2013 12:05 AM |
| Protecting plastic door threshold | BMWDavid | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-19-2012 09:04 PM |
