Drives: '17 86
Is it bad to have my ankle fully extended forward when pressing the clutch?
Hi,
I've been driving a manual transmission for all of 2 weeks and have finally found a comfortable driving position. The problem is, my ankle is extended forward pretty far when fully depressing the clutch. I've read around on correct seating positions and have found that the ankle should be still when depressing the clutch. Most videos I've seen also reflect this. Unfortunately, if I were to move the seat forward any more, I would have to bend my right ankle [over the brake/accelerator] backwards (uncomfortably) at rest. I also feel that at this position, I have the most control over the clutch pedal at the friction zone (possibly due to the high engagement point?). I started looking into this because I noticed that sometimes when I shift, the clutch has maybe 0.5 - 1cm of travel left that I'm not using and I don't want to end up unnecessarily damaging anything. If anyone has any thoughts or advice, I'd really appreciate it. Last edited by cat94; 11-21-2016 at 12:37 PM. Reason: Clarification |
#2 | |
Drives: UltraMFrS
Uhm idk if it's much use to you but I rises my seat so the ball of my feel has a height leverage when depressing the clutch, this allows you to basically sit far or close. If your leg is uncomfortable you slide the seat than use the steering wheel adjuster to match how far you slide back or forward |
#3 | |
Drives: '17 86
Also, I just went on a quick drive and found that one click forward is more comfortable for the clutch, and one click back is more comfortable for the brake and accelerator. |
#4 |
Drives: UltraMFrS
Hmm how to put this..
I slide my seat forward, so when I place my left foot on the clutch without depressing it my thigh are not resting on the seat, when I depress the clutch all the way down my thigh are resting on the seat and when I don't use the clutch I rest it on the dead paddle (helps not riding the clutch) . Mean while my right foot is comfortable with both brake and gas paddle. I pulled the steering wheel outward as I lean my seat backward so I can relax and the wheel is close for maneuvering |
#5 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I wouldnt leave my foot over the clutch at rest anyway so scoot up a click and put your foot on the dead pedal unless shifting.
Or if you insist go to the diy section and learn how to adjust your clutch pedal so it sits lower |
#6 | |
Drives: UltraMFrS
Yeah that's what I basically said about the dead rest. Leaving your foot on the clutch isn't a good habit lol. Adjusting the clutch could work too but seem like a hassle. Try if you will |
#7 |
Drives: '17 86
Sorry, I may have been a unclear. What I meant by at rest was my right foot just barely touching either the break or the accelerator pedal. My clutch movement is like how turtlefeeder described.
#8 |
However is comfortable to YOU is the right way.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | humfrz (11-21-2016), jasonojordan (11-21-2016), Muaddib (11-21-2016), p1l0t (11-21-2016), Ultramaroon (11-21-2016) |
#9 |
Feeling like thinking....
True, but in light of the O.P.'s point that he has a grand total of two weeks' experience driving a manual transmission, the points that some of the other posters made about NOT leaving your left foot on the clutch pedal are pretty important. Set your seat so that your right foot feels good to you on the accelerator and brake pedals, you have the back support and angle you like, and good visibility, then set your steering wheel to what feels best to you with your seat set properly. A good guideline is to put the wheel so that your wrist or the very bottom of your palm rests on the top of the steering wheel with your back against the back of your seat and your arms fully extended.
Note that I didn't say anything about the clutch. Compared to the wheel and the accelerator, you use the clutch relatively little. Keep your foot off the clutch unless you're in the act of changing gears. I don't track my car, and don't race. I'm sure competition drivers would feel more strongly about an exact placement of the clutch pedal for that extra level of comfort, but even in spirited daily driving, it's really not an issue. The original phrasing of the question makes it sound like your left foot is always touching the clutch pedal, and that's a bad idea. If your left foot is on the dead pedal (the metal resting plate to the left of the clutch, just in case you're not familiar with the term, OP) unless you're in the act of shifting, you'll be comfortable. Welcome to the world of manual transmissions.. it's a LOT of fun, and, IMHO, gives you one more level of connection to your car. Best, Barry |
#10 |
#11 |
Drives: 2013 Pearl White 6MT
Don't press it with your hands, because then you'll have a bad day as well as the others around you
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#12 | |
Drives: '17 86
Edit: I just looked at the original post again and read it as if my left foot was resting on the clutch when not in use heh.. Last edited by cat94; 11-21-2016 at 12:38 PM. Reason: Additional note |
#13 |
I drive barefoot for better feels
Sent from my SM-G920P using Tapatalk |
#14 |
I'm pretty sure it's against the rules but I don't know why.
On a road trip, my shoes don't last an hour. That includes twisties.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | p1l0t (11-21-2016) |
| Whining noise when pressing clutch? | cupcake917 | Issues | Warranty | Recalls / TSB | 14 | 03-12-2019 01:49 PM |
| Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. | Rybot | Issues | Warranty | Recalls / TSB | 35 | 03-06-2016 08:23 PM |
| clutch won't fully engage/8000 miles small dent | stockscionfrs | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-14-2014 11:06 AM |
| Car sensing clutch fully engaged when its not// | 504 | Issues | Warranty | Recalls / TSB | 1 | 09-16-2014 10:02 AM |
| Pressing/releasing clutch pedal - audible click sound (not the clutchs switch | tanner | BRZ First-Gen (2012+) — General Topics | 26 | 06-03-2014 08:24 PM |
