Old 01-25-2016, 12:25 PM   #1
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Intec headlight not projecting light
I think the mechanical internals are messed up. The bulb works and it is seated properly. Has anyone else had any issues with their spec-d headlights?
Sent from my SAMSUNG-SM-N920A using Tapatalk
**UPDATE** The headlight is fixed. I guess I hit the high beams enough for it to project the light.
texasbound972 is offline   Reply With Quote
Old 01-25-2016, 12:44 PM   #2
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by texasbound972 View Post
I think the mechanical internals are messed up. The bulb works and it is seated properly. Has anyone else had any issues with their intec headlights?
I'm afraid you might be the only person on planet earth that owns these due their insane price. Having said that, I hope you rectify the issue as these lights are very nice
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following 2 Users Say Thank You to JPxM0Dz For This Useful Post:
Nsot (01-25-2016), texasbound972 (01-25-2016)
Old 01-25-2016, 01:36 PM   #3
texasbound972
USMC
Correction, spec d headlights.
The Following User Says Thank You to texasbound972 For This Useful Post:
JPxM0Dz (01-25-2016)
Old 01-25-2016, 01:50 PM   #4
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
No issues with my Spec-D. What is your problem? Turn signals? DRL Boomerangs?
They're in a projector so they should light up when the bulb is on.
YamahaR86 is offline   Reply With Quote
Old 01-25-2016, 01:55 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah my Passenger flap get stuck on high beam some times lol. I just flip them on and off real fast till it goes back
Old 01-25-2016, 02:36 PM   #6
texasbound972
USMC
I tried that too. Mine also gets stuck. I think it might be internal. Not sure if these are able to be taken apart and fixed or if I just have to cut into it.
Old 01-25-2016, 02:53 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I think they just bake open. I will be retrofitting new projectors into mine in the spring as well as make the boomerang a full switchback. I may also black out the chrome bit in there too
Old 01-25-2016, 02:59 PM   #8
texasbound972
USMC
I like your style sir! Are you putting the mirimoto projectors in? I think I spelled that right.
go_a_way1 (01-25-2016)
Old 01-25-2016, 03:07 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah I think those were the ones I was looking at. Going to do proper research after I get all my suspension goodies on
Old 01-26-2016, 12:06 PM   #10
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Let me know how that works out when you do it. I was going to do it but don't have the funds at the moment, I just applied a new clearcoat for the peeling as well. Not sure how I feel about the boomerang switchback since it already has a turn signal built in and I have enough turn signals as it is (Headlights, Stock turn signals where the fogs are, side markers, arrow mirrors, and tail lights). I was considering taking out the current boomerang LEDs and putting in "True White" since right now it's bluish/purple.
TRS sells a kit for Spec-D headlight projectors. Not sure if it's plug and play but it might need smaller adjustments like drilling mounting holes. Honestly, in the long end I would replace the Spec-D projectors. They're pretty crappy as they're projectors for halogen bulbs and not HID. That's why it has a weird cutoff line and erratic hotspots where the light is focused on one area and not evenly spread out.
Also, since you got the Spec-D with us, eventually the UV coating for the headlights will peel. I just fixed mine with a kit.
Old 01-26-2016, 01:33 PM   #11
texasbound972
USMC
Yeah the top of mine is peeling. The high beam sticks most of the time and I have to hit a bump for it to go back down lol. Can you post a link for the replacement projectors? Thanks!
Old 01-26-2016, 01:40 PM   #12
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Wow, I hadn't actually checked the price on the Intec headlights. Are they ACTUALLY $2000 a pair?!
How is the lighting on them? Do they hold up to the claim that they have better visibility than HIDs?
Sorry you're having issues with them! For that price, they should work right out of the box with no issues... and give you a reach-around, too.
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 01-26-2016, 03:25 PM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
He should definitely change the title of post. He has the cheaper Spec-d headlights
Old 01-26-2016, 05:19 PM   #14
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Here's the thread I started a while back when I was interested in them but holding off because of funds.
Spec-D Headlights Retrofit?
Link to the product if you don't want to read through it.
And here is my results of a headlight clearing kit which I used to apply a new clear coat.
Headlight Restore Kit
The Following User Says Thank You to YamahaR86 For This Useful Post:
texasbound972 (01-26-2016)
[SOLD][RHD] INTEC FULL LED EURO HEADLIGHT + LED FOGS + BEZEL 750US$ Paulo86 Exterior Parts (Aero, Lighting, Etc.) 20 03-20-2016 06:09 AM
Headlights projecting on the floor Bhim Issues | Warranty | Recalls / TSB 12 03-14-2015 12:44 AM
INTEC JAPAN 92 LED Tail Light Available Now!! nigel-jdmparts Groupbuys 9 10-27-2014 10:58 PM
INTEC JAPAN 92 LED Tail Light Available Now!! nigel-jdmparts Exterior Parts - Lighting 2 08-17-2014 09:15 PM
