Drives: Intereted in 86 but now got G37
Q: coilover damper setting. front stiffer or F/R the same
Hi guys, I just installed my flex z and now I am wondering what is the best damper setting between front and rear to get the best traction and proper weight transition during cornering. Suppose for the enthusiastic driver mode.
Thank you guys!! |
#2 |
Only happy when it rains.
Drives: series.blue
It really depends on how you drive and your driving style, what you are looking to get from the car and how you want it to feel.
Trial and error really is going to be your best bet to figure out what is best for you. I would start by setting all of them right in the middle and slowly trying out each setting to see what you like best. |
#3 |
Drives: 2013 Scion FR-S 10 Series
Here's a good place to start: http://www.koniracing.com/rrtuningguide.cfm
| The Following User Says Thank You to RJasonKlein For This Useful Post: | finch1750 (11-19-2015) |
| ★★★★ Circuit Sports FRS/BRZ HIGH PERFORMANCE Inverted Coilover Damper Suspension ★★★★ | JonMotoring | Brakes, Suspension, Chassis | 14 | 04-21-2015 09:39 PM |
| Spring and damper rates: front vs rear, explanation needed | Ashikabi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-14-2015 04:21 PM |
| Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 02-20-2014 03:50 AM |
| Need Advice on 225 front and 245 rear tire suspension setting. | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-15-2013 06:32 PM |
| Coilover make and setting comparable to stock | VENOM~ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 03-03-2013 03:13 AM |
