Old 07-11-2015, 12:38 PM   #1
DGM.BRZ
Drives: 2015 DGM BRZ
OFT Macbook VMware Fusion
I am running windows 8 on my macbook pro using VMWare Fusion and for the life of me I cannot get my oft to reliably communicate with the openflash manager. I get a slew of errors anytime I try and do anything. I am running openflash manager in administrator mode and I tried compatibility mode and I even set VMware to run usb in only 2.0. The closest I got to getting it to work was setting my usb to run in 2.0. It will recognize the oft and read it but will not write anything to it. Please help!
DGM.BRZ is offline   Reply With Quote
Old 07-11-2015, 02:57 PM   #2
k.houan
k.houan's Avatar
Drives: BRZZZ
I find using parallels is a lot more reliable than VMware fusion on my macbook pro.
Sent from my SAMSUNG-SM-G925A using Tapatalk
k.houan is offline   Reply With Quote
Old 07-12-2015, 10:40 AM   #3
DGM.BRZ
It turns out its not just my macbook. I borrowed a friends laptop with windows 8 and it is doing the exact same thing. I hope its not my oft.
Old 07-12-2015, 10:50 AM   #4
JHEUNG
Drives: '15 BRZ Sport-tech
Had a problem with mine yesterday... Try uninstalling Open Flash Manager and then installing it again and don't forget to run the patch they have for Windows 8.
JHEUNG is offline   Reply With Quote
Old 07-12-2015, 11:19 AM   #5
DGM.BRZ
Did all of that about 5 times. I have spent about 8 hours trying to get it to work now. I have tried literally everything even on a different laptop. Could it possibly be that I only have usb 3.0 ports and not any usb 2.0? I know that usb 3.0 is backwards compatible so that shouldnt be it.
Old 07-12-2015, 11:20 AM   #6
JHEUNG
I used my USB 3 port so that shouldn't be an issue... Mind screencapping the error messages? Where and when we're you getting the error messages?
Old 07-12-2015, 11:28 AM   #7
DGM.BRZ
I get an error message anytime any sort of communication is done between the oft and ofm. It can read the oft but it refuses to write to it. I will grab some screenshots and post them up in a few.
Old 07-12-2015, 12:05 PM   #8
DGM.BRZ
Well I dont know if the servers were just down or something but it works now
Old 07-12-2015, 12:16 PM   #9
DGM.BRZ
I am still getting these error messages, although I was finally able to write roms and upgrade my device so I don't know what is going on.
Old 07-12-2015, 01:40 PM   #10
DGM.BRZ
Now the damn thing won't communicate with my ECU. I was able to flash a rom before it updated now it won't communicate with my ECU after I updated the OFT through openflash manager. I don't know if I was sent a faulty unit or what but this is frustrating.
Old 07-13-2015, 10:08 PM   #11
DGM.BRZ
Anybody able to help? I basically have a $500 paper weight until I can get this to work
Old 07-13-2015, 10:13 PM   #12
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
This error is caused by not having a WIFI connection. You can click OK and continue to use OpenFlash Manager. It just won't apply updates to the OFT.
Shiv@Openflash is offline   Reply With Quote
Old 07-13-2015, 10:15 PM   #13
Shiv@Openflash
Drives: 2013 FRS
You may need to be more specific about the OFT not communicating with the ECU. What error message? At what step? There has been no applied update that would make a once communicating OFT non-communicative. So instead of polling the forum for help, I think the best course of action would be calling us tomorrow during business hours. We can walk you through the process and get you sorted out quickly. Shouldn't take more than a few minutes if you have your car handy.
Cheers,
shiv
Old 07-14-2015, 09:07 AM   #14
DGM.BRZ
Okay thank you shiv I will be calling hopefully sometime today
OBD Fusion app - PID for oil temp? acj47 Engine, Exhaust, Transmission 2 06-16-2017 02:30 AM
'13 Ford Fusion poormans_LFA Other Vehicles & General Automotive Discussions 41 01-14-2016 06:29 PM
Ford Just Unveiled A Fusion That Weighs As Little As A Fiesta dem00n Other Vehicles & General Automotive Discussions 15 06-04-2014 12:25 PM
