#1 | |||||
Drives: 4-Runner Sport - 13' BRZ SportTech
Bad Experience with AVO Turboworld
So it pains me to make this thread, but unfortunately I've hit a wall and have no other choice. I've come to the conclusion that I'm going to take a $150-$200 hit on the chin due to laziness, poor communications, and from my perspective, a lack of care towards customer impact. I've purchased A LOT of AVO Turbo products over the past year and everything has gone as planned as long as there weren't any hiccups. Customer service has always been "ok", but never did I ever feel a sense of urgency when things went sideways. Up until this point, things would get resolved, albeit at their own pace.
The problem: I ordered a few small bits (upgraded actuator, gaskets for the millionth time, bushings, etc) and I decided to add on the STI Engine mounts at the same time. They were in stock, I was gonna get them anyways, so I figured why not. I live in Canada, but only an hour away from North Dakota. I frequently ship to the border and pick it up myself to save a ton in shipping and duty brokerage. ORDERED: Oct 2nd 2014 PICKED UP AND BEGAN INSTALL: Oct 8th 2014 I had the car up in the air and started disassembling the motor mounts while I was under there doing some other stuff. After about 20 minutes of pure confusion as to why the passenger side engine mount would not go in, I figured I should take a step back and make sure everything was correct. This is what I found: ![]() If you look closely, the two STI mounts (the ones with the ST markings) are identical. The mounts should not be the same as they mount on either side. I confirmed this by looking at the OEM mounts and noting that they had two different part numbers stamped on them. AVO had sent me two IDENTICAL engine mounts (drivers side) as opposed to one passenger and one drivers side. This is a big problem because I had my car up in the air and I need to put it back together. I immediately emailed Paul @ AVO. Quote:
This was emailed to me on Oct 9th: Quote:
Oct 14th, no email or contact of any kind so I emailed Paul to find out whats up. Politely obviously Quote:
OCT 16th: Paul did they send you a tracking number? - Response: It should of been sent. I'll check. No email after this one. OCT 17th: Another email sent asking If he has a tracking #. NO RESPONSE. OCT 21st: Another email sent "Any word yet? I'm assuming i'ts been sent out, I just wanted the tracking # to see where it is."... response: "I'll get on that". No email afterwards. OCT 27th: Another email sent "Any word yet? Just need to know that it was shipped to put my mind at ease. "... NO RESPONSE. OCT 31st: ANOTHER email sent "Paul, I really need to know what's going on with that engine mount issue. I have one STI mount and one OEM mount in my car. It's been a couple weeks at least with no tracking #. I've been exceptionally patient up until this point. Please get this resolved ASAP. -Alex" NO RESPONSE. At this point, I don't even want the mount from them. I have one OEM mount and one STI mount in the car. It's stored until spring so I can't put it in anyways. I'll order a single mount from another vendor and move on with life. I'm absolutely disgusted by the customer service that I've received. My current list of AVO parts is as follows: AVO Stage 1 Turbo Kit AVO 50/50 Blow off Valve AVO Upgraded actuator AVO 2.5" overpipe AVO 3" downpipe AVO 3" overpipe AVO 3" front pipe AVO Anti Tramp bushings Converted to Canadian funds, I've spent over $6000 with this company over the past year. Just a heads up for anyone else considering doing business with @AVOturboworld ... it's an okay product I guess, just make sure that you buy local and make sure you see the product before you buy it. This isn't meant to offend or throw anyone under the bus. I'm just sharing my experience because I'm not happy with how things went at all. I gave MANY chances to make the situation right.
Top Tier Imports - Check out my build journal HERE
| The Following 4 Users Say Thank You to protpibe For This Useful Post: |
#2 |
Drives: 2014 Pearl White BRZ
I am very sorry to hear about this. Paul has been very helpful to me and I can only guess that the issue is on the other side of the ocean and he may not be getting a response himself. I know he was busy getting ready for Sema etc. Who knows. I am sure they will make it right. Good luck!
| The Following User Says Thank You to Fastbrew For This Useful Post: | protpibe (11-20-2014) |
#3 | |
I thought so too, which is why I exercised patience over the course of about 5 weeks and MANY ignored emails nestled between blind assurances. If he had no intention or the means to correct the issue, he should of just told me "too bad so sad" instead of leading me on since the beginning of October. I'm sure there are many good experiences with avo out there, but let's be honest, it's not very hard to accept an order, throw it in a box, then mail it out. A company's dedication to its customers isn't tested on an average transaction, it's tested when things go wrong. And in this case, it's an epic failure that leaves me out a couple hundred dollars. Lesson learned.
#4 |
Drives: Whiteout FRS, Audi A4, 135i (sold)
Wow. That sucks
I'd be fired from my job if I handled customer relations like that.
boooooooooooooooooost
| The Following 2 Users Say Thank You to Ammonia For This Useful Post: | protpibe (11-20-2014), Sportsguy83 (11-20-2014) |
#5 |
I Love custom Turbo kits
Drives: Limited BRZ
#6 |
Fiebru
Drives: Scion FR-S and Integra Type R
Same here, after lots of emails I never received the replacement pvc block for my air breather tank that didn't fit and the IC which mine got damaged.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
| The Following User Says Thank You to Draco_PR23 For This Useful Post: | Sportsguy83 (12-03-2014) |
#7 |
Drives: Moped
Well this seems to be a trend...lovely
![]() ![]() ![]() Would love to hear the vendor's side, but I doubt they will show up.... |
#8 |
Sending rods to their doo
Drives: 700HP STi
On the U.S. side Paul is pretty much a one man show. I've seen it personally.
#9 |
Paul pm'd and emailed me to apologize, which I believe to be sincere.
The replacement mount is enroute. I'll post here when it's resolved.
| The Following 3 Users Say Thank You to protpibe For This Useful Post: |
#10 |
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
This AVO is not actually a huge operation just one dude the customer service was not up to par that is for sure but I'd cut him some slack...also parts coming from japan take time (sometimes months)
check out my build thread here
![]() Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
| AVO Turboworld | Sportsguy83 | User/Vendor/Sponsor Reviews, Feedback, Comments | 31 | 07-02-2014 01:05 PM |
| AVO Turboworld BRZ Front lip | zex | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-12-2014 01:01 PM |
| AVO TURBOWORLD 2.5 IN Catback NON-RES | killerkid08 | Engine, Exhaust, Bolt-Ons | 70 | 03-01-2014 08:57 PM |
| AVO Turboworld has moved! | AVOturboworld | Northwest | 27 | 02-13-2014 08:30 PM |
