Drives: Subaru BRZ
Is thermal insulation recommended for aftermarket catback exhaust?
My BRZ is the first car to which I’ve considered adding an aftermarket exhaust system (just a cat-back for now). Based on the photos in a number of installation threads, I am a little concerned about the heat effects of reducing the air gap between the exhaust pipe and the walls of the transmission tunnel and components adjacent to the exhaust.
Would adding some thermal insulation, at least for the first few feet downstream from the catalytic converter be recommended? Is there a particular type of insulation that would be recommended for this application? An example of what I was considering is something like this: http://www.heatshieldproducts.com/au...rs/lava-shield |
#3 |
Drives: Nuisance BRZ
^ This. You shouldn't have a problem at all
#4 |
Add lightness!
Drives: 17' WRX
Anywhere the factory exhaust has a heat shield, you should also make provisions to manage heat. On this car the header and overripe are probably the most important areas. I like themotec turbo heat wrap and dei titanium heat wrap for products.
#5 |
Drives: asphalt FR-S
heat shields if you must, but don't wrap the pipes.
http://www.centuryperformance.com/ex...o-not-use.html |
#6 |
Drives: Subaru BRZ
Thanks all for the feedback. For the time being I am leaving the factory heat shrouded components alone. If I ever swap things in the under hood exhaust I've seen a few threads discussing heat issues there that I can refer to.
#7 |
Drives: Scion FR-S
Anyone tried reusing the OEM heat shielding? I haven't replaced the header yet (Ft86SF header on order and you know the wait times on those), but thinking of trying to reuse if it's at all possible.
#8 |
in orbe terrum non visi
Drives: violent
overpipe and header is the only thing that needs heat management products.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp | fooddude | Engine, Exhaust, Transmission | 11 | 08-11-2016 06:18 PM |
| Recommended aftermarket mufflers/resonators on stock exhaust | BlueDubbinTDI | Engine, Exhaust, Transmission | 10 | 09-14-2013 09:39 PM |
| Recommended Tire Pressure for Aftermarket Wheels and Tires | Chri5 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-15-2013 01:28 PM |
| Are there any good/recommended aftermarket stereos? | redwing634 | Electronics | Audio | NAV | Infotainment | 23 | 09-30-2012 02:29 AM |
