Drives: Really slow
Pick 2 gauges for turbo build.
I will be able to mount 3 gauges (1 AC vent and 2 defroster pod) when I do FI for the first time in my life next month. I will be running an AEM wideband failsafe in one of the spots. Not quite sure which are the next two most important gauges to mount for this application.
1. Oil Pressure 2. Oil Temperature 3. Coolant Temperature This is probably a noob question but any help would be appreciated. |
#2 |
Drives: Attitude
AFR/boost combo gauge, then oil pressure and/or temperature.
#3 |
Drives: 85 corolla gts
http://www.innovatemotorsports.com/products/MTXD.php
they have a dual gauge for oil temp and pressure, then from there egt would not hurt. |
| The Following 2 Users Say Thank You to Ross For This Useful Post: | 1stGenBRZ86 (03-26-2014), Cheeseballs (03-24-2014) |
#4 |
Drives: Sterling BRZ Ltd
this
| The Following User Says Thank You to mrk1 For This Useful Post: | Cheeseballs (03-24-2014) |
#5 |
Drives: Attitude
Solid advice from @Ross. Boost/AFR, Oil T/P, EGT...you're now monitoring the most vital things you need to monitor.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Cheeseballs (03-24-2014) |
#6 | ||
Drives: Really slow
#7 |
Drives: Attitude
FYI @Cheeseballs EGTs can be tricky since you need to have a bung for the thermocouple - are you still on the stock header? Stock header will require drilling/welding a bung to use EGT whereas most aftermarket headers (of quality) come with at least one bung, if not more. Unless your gauge can accommodate four sensor inputs, you're going to want to put the sensor in the hottest exhaust runner; traditionally for the turbo Subarus this has been the runner from the #4 cyl, though I can't with any veracity make that claim on this engine.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Cheeseballs (03-26-2014) |
#8 |
I'm getting PLX gauge, which either plugs into your car's OBD port, or you use their modules for whatever you want to monitor.
Each gauge can show a bunch of different hings, you just scroll through to whatever you want to view. http://www.plxdevices.com/product_info.php?id=MULTDM6 |
#9 |
in orbe terrum non visi
Drives: violent
innovate oil pressure/temp combo gauge, innovate water temp, aem failsafe afr/boost,
#10 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
IMO
AEM Failsafe, EGT gauge and an oil pressure. Temp is important, but not quite as important as your pressure suddenly falling off the map. Again, IMO.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#11 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I went with 2, the AEM failsafe and Innovate MTX-D for Oil Pressure and Temp in 1 gauge. If I were forced to pick a 3rd gauge, it would be water temp
Top Tier Imports - Check out my build journal HERE
#12 |
NASA SpecE30 Racer
The OEM water temp sensor in your gauge cluster is effective enough. I might go with a fuel pressure one if I was running a heavily modified fuel system or a high boost setup that taxed the fuel pump.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Calum (03-24-2014) |
#13 |
![]() When this goes in to production in the next couple of months it will be an excellent option. AFR, Boost (up to 44psi), boost control, boost cut by RPM and/or AFR, programmable shift light, and 0-5v analog output for AFR. You can also log solenoid duty cycle, manifold pressure, AFR and engine RPM to your laptop or iPhone provided you use it in conjunction with the OT2 device. You can also daisy chain this device with our other MTX-D series gauges to also log your oil pressure, oil temp temperature, etc. A ton of functions for a single gauge. |
| The Following 2 Users Say Thank You to mines13 For This Useful Post: | Cheeseballs (03-26-2014), Hawaiian (03-24-2014) |
#14 |
Drives: Attitude
| Just Another (Turbo) Build | rb6freak | Member's Car Journals | 184 | 03-22-2017 09:25 AM |
| Do Boy's Turbo FR-S build!!! | Do Boy | Member's Car Journals | 417 | 11-29-2015 02:17 AM |
| Turbo Kit & Shop Car Build | Carolina Dyno | Forced Induction | 11 | 01-22-2014 03:59 PM |
| pick-a-turbo for beginners! | subatoy | Forced Induction | 20 | 07-25-2013 07:09 PM |
| Gauges for Turbo, boost controller options? | gdrider77 | Forced Induction | 27 | 05-13-2013 06:57 PM |
