Old 03-04-2014, 06:32 PM   #1
dragonwiddd
dragonwiddd's Avatar
Drives: 2013 Scion FR-S Asphalt
Storing for a year
Well I'm moving to Korea for a year in April and will be keeping my car in Florida the whole time. Will prob. store in a storage unit. What steps should I take to prevent any damage from the car sitting still for a while? I was thinking about raising the car about a half an inch off the ground or just enough to take weight off the tires to protect them. Not sure what to do with the fluids and battery. Should I leave the batt in and have someone start it once a week and let it run for 10-15 min?
dragonwiddd is offline   Reply With Quote
Old 03-04-2014, 06:37 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Gas up the car until Full and add fuel stabilizer. A full tank will have less condensation than an empty tank.
Remove the positive battery cable and tuck it away.
Put tire PSI to near MAX PSI (avoids flat spotting.)
Stuff a sock into the exhaust tip.
And perform an oil change.
Wash and wax the car.
Lock the car and have fun in Korea!
I would not suggest covering the car (unless it's outside), better to just come back and wash it.
The Following User Says Thank You to N1rve For This Useful Post:
Rayme (03-05-2014)
Old 03-04-2014, 06:56 PM   #3
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
^ What he said, and also:
Put it in first gear, and don't forget to leave the hand brake down
Best bet is always to store your car on tires you don't care about (steelies with cheap used tires)
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 03-04-2014, 07:16 PM   #4
Aaron.H
Aaron.H's Avatar
Drives: 2014 Whiteout FR-S
And don't forget to chalk the front wheel or if in reverse chalk one of the rear wheels
Aaron.H is offline   Reply With Quote
Old 03-04-2014, 07:16 PM   #5
D88
D88's Avatar
Drives: 2014 Scion FRS
Out of curiosity, he said he might raise the car off its wheels but @N1rve didn't comment on that. Is there anything wrong with this?
D88 is offline   Reply With Quote
Old 03-04-2014, 07:23 PM   #6
I understand that it's not good for a suspension to "hang" for any length of time.
Old 03-04-2014, 07:31 PM   #7
Originally Posted by dragonwiddd View Post
Well I'm moving to Korea for a year in April and will be keeping my car in Florida the whole time. .................. Should I leave the batt in and have someone start it once a week and let it run for 10-15 min?
Well, best yet, after about 7 months (next winter), have someone drive it around Florida for about 3 months. Yep, since I'm retired, I could do that for you. Do you have a house that needs sitting .. ?? ....
ntron1 (03-05-2014)
Old 03-04-2014, 08:07 PM   #8
N1rve
N1rve's Avatar
I don't like things sitting in the air.... I don't know if it's possible but.... what if a earth quake hits and shakes the car off the jackstands?
Or some food that needs eating?
Old 03-04-2014, 08:12 PM   #9
thebus
Drives: Whiteout
Not sure how secure this storage facility is against mice.. Nor would I have a logical idea how to protect against them but like said above those are good
thebus is offline   Reply With Quote
Old 03-04-2014, 08:50 PM   #10
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Florida=Hurricanes, not earthquakes...
CircuitJerk is offline   Reply With Quote
Old 03-04-2014, 09:16 PM   #11
N1rve
N1rve's Avatar
That's just as bad if not worse LOL
CircuitJerk (03-05-2014)
Old 03-04-2014, 09:42 PM   #12
Oh, yes ...... I'd take care of them steaks, so as they don't get freezer burnt .....
Old 03-05-2014, 07:57 AM   #13
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
If you're military, look at having them store it.
slicktop is offline   Reply With Quote
Old 03-05-2014, 08:12 AM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
What N1rve said. And do not jack the thing up. Also I would highly recommend when it's the time to start it again after a year, to crank the engine with the EFI fuse removed, sometimes the oil drains down and the engine will be quite bone dry with all the oil in the sump. Cranking it for 10-15 seconds a few times, it will pump the oil with no load on the bearings.
Rayme is offline   Reply With Quote
Storing Car For 9 Months Touge86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 11-11-2013 10:21 AM
Storing my car SmsAlSuwaidi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 06-22-2013 06:38 PM
Anyone storing their aftermarket parts until... ScionFrsFan Issues | Warranty | Recalls / TSB 6 01-07-2013 07:01 PM
Limited number this year and next year? manonastick AUSTRALIA 4 06-24-2012 06:32 AM
Storing an unused car? #87 Off-Topic Lounge [WARNING: NO POLITICS] 10 02-21-2012 10:51 PM
