Drives: 2013 Premium White, 2006 TL
You guys have any cool and interesting ways to eyeball Alignment?
So I know there are some super ingenious people on the forum. I would love to hear some easy fun and interesting ways to DIY in your garage to do a rough alignment after doing major changes in suspension. Using string, iPhone apps, levels, eyeball, friends, etc. Let's find a fun and easy way to dial in our cars for ride height, spring settling, etc, without toasting the tires during the process. Hopefully his will be a great set of ideas to make DIY easy.
Sent from my iPad using Tapatalk |
#2 |
Drives: 13' Subaru BRZ Limited SWP 6MT
Disclaimer...there's no substitute for an alignment machine.
With that said there are two things you can do for a "home alignment."
| The Following User Says Thank You to mwjcyber For This Useful Post: | DrDuquette (02-22-2014) |
#3 |
Drives: 2013 FR-S Argento
#4 | |
#5 |
Drives: 2013 GBS BRZ Limited
I use 4 jackstands (I have a 914 so 4 jackstands is a requirement) to hold straight lines (fishing line or welding wire) down each side of the car about ~4 inches out from the outside wheel surface.
This will usually take ~5 minutes to get them all the same distance from the car. (to within ~1/16 inch of each other) I use these lines to measure Toe. This requires some basic math & geometry to determine front & rear toe (and to get the steering rack centered). And I use the craftsman digital level as mentioned above to get the camber. This also requires a little math as, chances are, the car is not sitting level to start with. |
| The Following User Says Thank You to stugray For This Useful Post: | DrDuquette (02-22-2014) |
#6 | |
An alignment tool just to get us buy for a few week UNTIL WE DO PROFESSIONAL ALIGNMENT. Thanks again. So cool that use made the places for you car to sit so that it can slide around and settle the suspension. Way cool!! Sent from my iPhone using Tapatalk |
#7 | |
Thanks Sent from my iPhone using Tapatalk |
#8 |
blowhard
Drives: frs, project forester
Toe is pretty easy to do a half assed check at home with straight edge items and tape measure
There's videos on YouTube And as others have said a digital level works. The jack stand string method has long been an accepted/preferred diy |
#9 | |
#10 |
I figured I might not be happy the first few adjustments. May need a few days to drive around and didn't want to burn up tires with toe issues.
#11 |
My local Honda dealership has a Hunter laser alignment checker. Just checked it out today - you drive your car into the service bay, they clamp on a target to each wheel, then slowly roll the car forward, and then they give you a printout of the alignment.
I also learned today that I need to get my alignment done.
#12 | |
If you have adjustable rear LCA's and you adjust them to remove some camber you'll end up with more toe than you want, but if you're not adjusting camber at home then your toe should be close enough that you're not burning off tires in a week or two.
#13 | |
| Ways to 'soften' stock rev limiter? | diss7 | Software Tuning | 26 | 09-27-2013 04:59 AM |
| Ways you COULD get of out a ticket | Muskokan | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 09-10-2013 06:42 AM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| common ways to sell online | three3y3wrbbrz | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 04-15-2013 02:20 PM |
| Some Cool dealer-info that could help you guys out ! | SCIONMONTREAL | CANADA | 36 | 04-04-2012 07:28 PM |
