Old 02-10-2014, 11:00 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thumbs up Aftermarket Wideband to Rear O2 signal
So I've spent the last few weeks tuning my car (or @jamesm tuning it and me trying to learn as much as possible). the process has sometimes been slow by not having the Wideband logged by Ecutek, which means anything below 11.02 AFR is not logged. This makes it hard to know how much fuel needs to be taken out of the tune and be able to reach target AFR's quicker (in summary, spend less time modifying the rom, flashing and more time fine tuning it).
Well @EcuTek responded quickly to the community requests and has provided us a way to log the Rear O2 input which otherwise is useless.
We now can connect our aftermarket Wideband (AEM Failsafe in my setup) to the O2 sensor wiring and have it all together in a nice clean Ecutek log! This also helps verify how well/bad is the stock O2 calibrated.
Below is what I did: (Special thanks to my good friend @jamesm who helped me figure it all out).
James showed me: from page 48 of the ecutek docs. Get that thing wired in and it'll make both of our lives much easier
Then i started digging into it:
So from the wiring diagram:
This is the A34 connector, and we need to connect to pin 21:
Pin 21 takes signal from the C13 Rear O2 connector, blue wire (see below) #3 on C13
Finally, below is C13, the Rear O2 connector. I'm in the process of connecting the Failsafe White cable (analog AFR output) to pin #3 in C13.
This is the table AEM gives for output AFR vs. Volts.
DONE!! Wideband is logged via Ecutek. Software update AND tune file update is required. This is only capable in Ecutek RaceRom 7.
Hope it helps!!
The Following 23 Users Say Thank You to Sportsguy83 For This Useful Post:
00vsmcoupe (11-19-2014), 86-tundra (02-11-2014), Circuit Motorsports (02-10-2014), civicdrivr (03-15-2015), cobrabyte (02-10-2014), diodelphi (02-07-2015), Draco_PR23 (02-10-2014), ftc~brz (02-11-2014), glorydays (02-10-2014), Ironsquid (02-11-2014), jamesm (02-10-2014), johnb831 (02-11-2014), Kakawate (03-20-2014), kbye (02-26-2014), Koa (03-02-2015), Lawnik (02-12-2014), Longuy (03-21-2022), M1K3 (02-10-2014), Manji (08-02-2014), OjiGeorge (04-13-2014), shiro (02-11-2014), u/Josh (02-12-2014), xkalelx (01-04-2016)
Old 02-10-2014, 11:01 AM   #2
Sportsguy83
Drives: Limited BRZ
Installation pics in the engine bay:
Old 02-10-2014, 12:51 PM   #3
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Awesome! Great work!
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
Sportsguy83 (02-10-2014)
Old 02-10-2014, 12:56 PM   #4
jamesm
I'll add that this opens up a whole new world of opportunity for RaceRom users, not just logging. I've been using wideband input on the CPC voltage line for a while now, for everything from full-time closed loop fuel control (awesome for tuning sd), to AFR target safety cuts (i.e. cut fuel/throttle/timing if AFR misses target by too much at a given boost level). It works quite well, and i have a screencast showing the results of my closed loop fueling tests.
this also allows me to run flexfuel now, so win .
The Following 3 Users Say Thank You to jamesm For This Useful Post:
Sportsguy83 (02-10-2014), u/Josh (02-12-2014), wparsons (02-11-2014)
Old 02-10-2014, 01:12 PM   #5
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Apparently the primary 02 sensor isn't a narrowband, but a pretty decent wideband.
^GT5 Replay Photo Mode^
Old 02-10-2014, 01:27 PM   #6
OrbitalEllipses
Drives: Attitude
Still a 4-wire unit isn't it? True wideband is moar better and has moar wires.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
Carsnguitars (08-25-2018), jamesm (02-10-2014), wparsons (02-11-2014)
Old 02-10-2014, 01:28 PM   #7
Sportsguy83
Drives: Limited BRZ
I would consider a nice wideband something that can read from 8-18
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (02-10-2014)
Old 02-10-2014, 01:31 PM   #8
jamesm
It's a planar-type wide-range o2 sensor, not a wideband. It has a narrower operable range, calibrated from the factory to be most accurate near stoich and slightly leaner than stoich. It can be recalibrated to read lower, but accuracy at richer afrs is not great.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Hyper4mance2k (02-04-2015), SirBrass (02-10-2014)
Old 02-11-2014, 07:47 AM   #9
wparsons
wparsons's Avatar
100% not useful to me at this point, but awesome for people that need a better wideband signal!!
Good work!
flickr
Sportsguy83 (02-11-2014)
Old 02-11-2014, 10:17 AM   #10
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
So you need to cut the blue wire from stock rear O2 sensor and connect AEM's white wire instead ?
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 02-11-2014, 10:30 AM   #11
Sportsguy83
Drives: Limited BRZ
Yes sir. I cut the O2 cable thus leaving the OEM harness intact.
You will also need to connect the Failsafe brown cable (Analog ground) to ground in order to get the proper reading and that's it. It works beautifully.
Old 02-11-2014, 10:52 AM   #12
swift996
swift996's Avatar
Someone make a plug and play!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
nunonuna (02-11-2015)
Old 02-11-2014, 11:14 AM   #13
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
well that just made wiring this to my P3Cars gauge a whole new game
http://www.innovatemotorsports.com/products/lc2.php
lbroskee is offline   Reply With Quote
Old 02-11-2014, 11:21 AM   #14
Sportsguy83
Drives: Limited BRZ
Yeah, will be basically the same that was needed for the AM Failsafe.
lbroskee (02-11-2014)
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
