Old 12-19-2013, 05:44 PM   #1
Etomatoeman
Bent rear suspension - advice needed
So I bought a salvaged Scion FR-S from an auto auction as a personal project.
It was damaged in the side. From the looks of it, I think someone drifted it into something.
I've done body Work before , but this one has suspension problems. The rear Passenger wheel is tilted, bottom in, top out.
The thing is, I took it apart and found the lower arm control bent, so I replaced it. But when I put it back together, the wheel is still the same, only slightly straighter.
There's obviously a problem. But from a visual inspection, I can't see anything bent.
Is/are there parts that are suspected damaged parts in this kind of an accident?
I'm at work right now, so I can't post pics. But ill post a few when I get home tonight.
Etomatoeman is offline   Reply With Quote
Old 12-19-2013, 05:51 PM   #2
charged86
charged86's Avatar
it could be anything unfortunately any alingment shop could probably spot it for ya.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 12-19-2013, 05:52 PM   #3
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Bent hub
Deadspool is offline   Reply With Quote
Old 12-19-2013, 06:31 PM   #4
d1ck
Drives: Black 2013 FRS
Wheel hub, trailing arm, subframe
d1ck is offline   Reply With Quote
Old 12-19-2013, 06:33 PM   #5
Etomatoeman
Yeah, I'd rather explore my options dry before I go that route.
Originally Posted by Deadspool View Post
Bent hub
I'm a noob, especially with suspensions. So what's the hub?
Old 12-19-2013, 06:34 PM   #6
Etomatoeman
Bent hub
Ah, never mind. A quick Google search answered that for me
I'll take it apart and compare it to the other side when I get home tonight
Old 12-20-2013, 06:48 AM   #7
wparsons
wparsons's Avatar
I would bet on a bent subframe, hopefully the unibody is straight in the back or you'll be sending it off to have the frame straightened.
flickr
Old 12-20-2013, 10:29 AM   #8
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
By the sound of it, you really should take it to a body shop and have them throw it on a frame jig to check if the frame is straight before you start. If you are lucky, only damage to the subframe and suspension in the rear along with the body work.
Old 12-20-2013, 10:54 AM   #9
Dezoris
Dezoris's Avatar
pull the rear carrier off (entire rear suspension frame mount) have the body shop look at sub frame. if ok replace rear carrier then replace the hub control arms etc on that side. leave carrier slighly loose when alignining so you can move left or right if need be to get more even camber numbers.
Old 12-20-2013, 12:00 PM   #10
Suberman
Drives: Subaru BRZ Sport Tech Satin White
You need to put it on a frame rack. There are tiny alignment holes everywhere in the body. The frame rack operator puts your car on the rack, dials in your car make, model and year and the little laser lights try and measure all the pre-set distances between the alignment holes.
That's how these unibodies are repaired. A skilled operator then attaches rams to the body in just the right places to pull the unibody straight. If they can't do it by pulling and pushing with rams they assess whether they can cut and weld. If not, the unibody is scrapped.
There is a very high probability that you bought a parts car.
Suberman is offline   Reply With Quote
Old 12-20-2013, 12:19 PM   #11
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
you need a frame rack.
TouchMyHonda is offline   Reply With Quote
Advice needed on wheel stud issue THEmailman Issues | Warranty | Recalls / TSB 6 12-16-2013 10:54 PM
Need some Suspension advice! LazerBrZ Mid-Atlantic 6 10-09-2013 08:36 AM
Need Advice on 225 front and 245 rear tire suspension setting. Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-15-2013 06:32 PM
What to do.. Advice needed fuddbutter AUSTRALIA 44 01-29-2013 07:02 AM
Advice needed: bargaining, leverage, and finally buying rainmonkey BRZ First-Gen (2012+) — General Topics 23 09-06-2012 09:50 PM
