Old 12-06-2013, 08:56 PM   #1
moe_5
Drives: 2014 scion FRS
Shifter Shaking
hi i own a 2014 frs and ive noticed that every time i slam gears the shifter shakes alot, is this normal?
moe_5 is offline   Reply With Quote
Old 12-07-2013, 01:02 AM   #2
Hi moe_5 and welcome to the forum.....
Well, the shifter on the MT of my 2013 doesn't shake.
You say you "slam" gears .... ??
I like to think that the proper way to slot the shifter into another gear in the FR-S is sort of like opening and closing the bolt on a 30-06, kind of slow but positive.
I'm sure others will be along with some more insight....
Old 12-07-2013, 01:31 AM   #3
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Shift like you have an egg in your hand.. Don't force it. Slip back into neutral and then back into gear if there is resistance. Your tranny will be much happier.
355rockit is offline   Reply With Quote
Old 12-07-2013, 01:51 AM   #4
Tromatic
Willing to bet "slam gears" means gas to the floor and upshifting from one to whatever as fast as possible, and lugging the hell out of the engine causing various things to shake. Has to be Fast and Furious related, because racecar.
Old 12-07-2013, 01:51 AM   #5
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I hope you aren't actually slamming the gears in if they don't go in like a knife through warm butter its probably better to rev match a little better
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 12-07-2013, 12:46 PM   #6
Poodles
Drives: 2015 Series.Blue
First FR/RWD car? As the shifter is directly mounted to the transmission, when you load the engine and transmission, the shifter is going to move. If you're breaking traction, it will shake as the tires fight for traction.
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage continuecrushing Issues | Warranty | Recalls / TSB 8 05-18-2013 11:56 AM
shaking of car Adam86 AFRICA 3 05-17-2013 08:42 AM
Violent shifter shaking when loss of trsction milenko11 Issues | Warranty | Recalls / TSB 2 12-15-2012 09:06 PM
