Drives: 2013 Raven FR-S
Best Buy/Sonic Electronix/Crutchfield speaker replacement
All I want is direct plug and play speakers for the doors. A simple saturday afternoon take of the door panel type of day. Ive called a bunch of retailers and they give me excuses about the door speakers not having proper fitment.
Has anyone found a good over the counter direct plug and play door speaker for the two side doors. I am leaving the 4 speakers on the dash and the two rears in place. Just want a cheap simple upgrade for the doors as they have limited range and seem to struggle... |
#2 |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
[ame="http://www.amazon.com/Infinity-Reference-6032si-Performance-Loudspeaker/dp/B002C8AFEE"]Amazon.com: Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair): Car Electronics[/ame]
I have these.
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
| The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post: | OrangeJuleas (07-12-2013) |
#3 |
How simple is this? I would look into getting something like this as well (will keep it looking fairly stock as well).
#4 |
Is it fast? No.
No different than any other speaker install. They just need to be shallow mount so the window doesn't hit the speaker on the way down.
#5 |
Drives: BRZ DGM Limited
How to they sound compared to stock??
#6 |
DADA
Drives: 2013
Window doesn't even get close to where the speaker sits. I ran the window up and down when I was doing the install to make sure of this .
#7 |
Drives: 86 GTS Auto in Pegasus White
You won't get "direct plug and play". The stock speakers have this funky plastic mounting bracket and the stock holes are not in "normal" positions. You could drill new holes in you door.... shudder....
So a couple of things that you should consider. You'll need a mounting bracket. You could buy one of those crappy black adjustable plastic ones, or get one that's custom made for the car like http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/ Or you could make your own. The second thing to consider and really the reason you are doing this, is you want your new speakers to push up against the door trim - this seals the speaker and pushes ALL the sound out into your car where you want it. The factory speakers actually do this. If you do that your mid bass will bang. Oh, and while you have the door trim off, I'd put in some sound deadening
| The Following User Says Thank You to Z86 For This Useful Post: | PatrickSAN (04-03-2014) |
#8 | |
#9 |
Drives: 2013 Subaru BRZ Sport-Tech in White
Installed these today: http://www.futureshop.ca/en-CA/produ...rchPageIndex=1
The plastic bracket was a little small for the hole cut for the stock speakers, but I ended up fastening 2/3 screws and double side taped the the last hole that didn't quite line up. This set also comes with crossovers which I managed to fit inside the door panel with relative ease. This set does not come with wiring (between speakers and crossover). I used stock wiring to the head unit. I removed the stock tweeters from the stock white adapter, attached the new tweeters to the same base, so I could attach the new tweeters without messing around with wiring. I did not connect the New tweeters to the crossover ... As well it was all the way inside the door. Overall, great sound. Door speakers have a very heavy low end. They do not distort or rattle like the stock speakers. I did not upgrade the stock amp, and still sounds great. Hope this helps! |
#10 |
Drives: Raven FR-S 6MT
I to have the same question as him. I was already looking at [ame="http://www.amazon.com/Infinity-Reference-6032si-Performance-Loudspeaker/dp/B002C8AFEE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1375137464&sr =1-1&keywords=6.5+shallow+mount+speakers"]Amazon.com: Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair): Electronics[/ame] and then I saw you had them.
| The Following User Says Thank You to RIPTRD71 For This Useful Post: | Tim_Asphalt_FRS (07-30-2013) |
#11 | |
Is it fast? No.
#12 |
Drives: Scion FR-S 10 #853
Does anyone know what the speaker specs are for the door speakers? Are those infinity's a decent bump or just a small one?
#13 |
Thanks for the response man. Im going to order those when i get off work! Thanks again!
| Front Stage Speaker Replacement - The Right way? | Gopherboy6956 | Electronics | Audio | NAV | Infotainment | 12 | 03-27-2013 03:39 PM |
| Good DIY for speaker replacement. | ST185RC | Electronics | Audio | NAV | Infotainment | 5 | 02-10-2013 02:47 PM |
| speaker replacement | pcporo | Electronics | Audio | NAV | Infotainment | 6 | 01-23-2013 02:02 AM |
| speaker replacement | 20valvewynn83 | Electronics | Audio | NAV | Infotainment | 3 | 12-12-2012 02:36 AM |
| Thoughts on ease of speaker replacement? | ahausheer | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-29-2011 11:16 AM |
