Originally Posted by Stimmed
Im sitting at 400hp on quite a low reading dyno. And its having no issues.
And at 400hp it is just quite absurd to be quite honest! anything above half throttle in auto mode to get on it a bit from a roll and your spinning wheels.
In manual mode getting on it decently it just spins 1/2/3 if your really into it. Fun but a bit scary!.
Driving in auto mode is actually realllllly sketchy if you are rolling along and decide do lay into it. You will just go sideways. SC might be a bit diff to turbo in that respect though as its not a rush of boost all at one time.
Originally Posted by Lunatic
250 @ 5800 rpm.
At what RPM are you making 400whp?
Cause at peak torque you're only making 276hp.
Assume you hit peak HP at 7k, You'd need 300 torque.
Even at 8k your cars torque would need to be higher than what you stated as your peak torque.
Your numbers don't add up.
