Originally Posted by rosol16
At about 30mph with wheel turned slightly like less than a degree I get a groaning sound similar to that of a power steering pump if you know what that sounds like. I would assume its not the power steering pump because we have electric steering. I will get a video if I can. It leads me to believe its a wheel hub/bearing?
Welp, the first thing I would do is check the tires pressures.
Next, I would rotate the wheels, front to back.
While I had the wheels off, I would inspect the brakes for a dragging pad and see if I had a lose caliper.
Also, check for a lose wheel bearing.
If none of that fixed it, I would have the alignment checked.
All that is
....... what I would really do, is take it up to my local auto shop and have them find and fix it .......... while I went next door and had a burger.......
