Washer Fluid Spray - Low Flow
I feel stupid for posting this but the solution is escaping me.
Running the washer on the windshield results in a spray that's about 6" or so out the nozzles.
I've blown out the lines and cleaned them with vinegar/distilled water. The spray using that level seems to be fine.
I've replaced the factory washer pump with a Trico aftermarket pump.
The results are the same. The spray is the same out of each side.
What am I missing?
