View Single Post
Old 09-15-2022, 08:51 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by CatNurseKelly View Post
I had new tires installed, and immediately began hearing a single, loud POP from the rear passenger tire area when making slow, sharp turns. Seems to be more consistent when turning left, but has happened going right. Never hear it any other time, just when pulling into my garage or similar speeds/turning situations. Cannot reproduce for tire guys, so just get the old shrug and blank stare. The timing of it has me wondering if anything was damaged when the tires were mounted?
I have a snip of video that catches the sound, but unable to attach here since it’s not in the right format.
Any ideas? I like to have as much info as possible before seeing a mechanic, since being a girl historically puts me at a disadvantage.
I have a 2017 86, with 52K miles. Tires installed are the correct size.
It could be one of a few things. A damaged CV joint, bad alignment and balancing, debris stuck somewhere on the wheels or tires, or loose hubcaps.
spcmafia is offline   Reply With Quote
