I agree that AIM is the way to go, but the annoying part about an AIM Solo 2 DL is that you can't add other sensors that aren't made available over CANBUS, you need to go up to a MXM or something to add in say, oil pressure. Obviously, if you have an aftermarket ECU you can pipe whatever you want into a DL but it is worth noting.
Also, the Smartycam 2.1 makes it easy but the video quality is garbage compared to basically everything else out. It writes the data overlay onto the video live so it needs the hardware to handle that, Smartycam 3 is coming out soon that does 1080p.
