Originally Posted by JaviBadger
Also, should I stay with the same size tire?
Sent from my Pixel 2 XL using Tapatalk
On stock wheels, probably should. You can try going to a 225, but not sure it will be an improvement. You get a tiny bit more surface area in tire itself, but the contact area won't change much unless your wheel is wider too. Going to make the odometer very slightly off and slightly negative effect acceleration too. Just switching to a proper performance tire will be worlds of difference and have a larger contact area than stock tires even though they are the same 'size' because of the profile of the tire.
